Thread: Code for PU 2294A |
New member Username: Pstamenic88
Beograd Serbia
Post Number: 1 Registered: Oct-09
| Posted on Wednesday, October 14, 2009 - 05:20 am: |
I need code for my car(Peugeot expert) cd player PU 2294A serial:CL040120797159 help meee...urgency thanks |
Gold Member Username: Regrooster
Post Number: 2031 Registered: Aug-08
| Posted on Wednesday, October 14, 2009 - 05:42 am: |
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing. (There are usually two barcodes on one label. The one required is the lower one ) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) |
Beograd Serbia
Post Number: 2 Registered: Oct-09
| Posted on Wednesday, October 14, 2009 - 07:47 am: |
OK. I found barcode serial number C7000006466 If you can send me it now please. Thank you so much!!! |
Post Number: 2043 Registered: Aug-08
| Posted on Wednesday, October 14, 2009 - 06:46 pm: |
Duplicate Post...Already answered Please do NOT post the same request more than once ! |
New member Username: Sahota
| Posted on Monday, October 26, 2009 - 11:58 am: |
hello i have a car stereo its a cd player its a PU 2294A the serial number is CL0401Y0168141 I NEED THE CODE PLEASE HELP |
Post Number: 2143 Registered: Aug-08
| Posted on Monday, October 26, 2009 - 03:36 pm: |
mani New member Username: Sahota Post Number: 1 Registered: Oct-09 Posted on Monday, October 26, 2009 - 11:58 am: hello i have a car stereo its a cd player its a PU 2294A the serial number is CL0401Y0168141 ============================= Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing. If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) |
