Thread: I need help badly, with my car's radio code |
New member Username: Cgreene
Post Number: 1 Registered: Oct-09
| Posted on Sunday, October 11, 2009 - 05:19 pm: |
I just recently changed the battery in my 2007 Honda Civic and when I went to listen to my radio again it said to enter its code. I never recieved the code when i bought my car. The serial # is 40051790. SOMEONE PLEASE HELP |
Gold Member Username: Regrooster
Post Number: 2017 Registered: Aug-08
| Posted on Monday, October 12, 2009 - 07:41 pm: |
HONDA RADIOS.................IMPORTANT NOTICE PLEASE READ BEFORE POSTING ANY CODE REQUEST ============================================= If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on Please note: The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy HONDA radios are made by the following manufacturers ALPINE AUTOSOUND BLAUPUNKT CLARION KENWOOD MATSUSHITA PIONEER The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by BLAUPUNKT. These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing UNFORTUNATELY ... NO OTHERS ! So you will be wasting your time posting code requests here for any other make. BLAUPUNKTS ONLY with a BP Serial Number ================================================= For EVERY other HONDA radio made by one of the other manufacturers then visit the website below https://radio-navicode.honda.com If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
New member Username: Sikeey
Post Number: 2 Registered: Oct-09
| Posted on Tuesday, October 13, 2009 - 02:29 am: |
Hi Please help, I have a Renault Megane 2005 i disconnected my battery and now my Auto Radio is asking for the security code. Please find details below. RNRC 235 000 1970 RENRCW 230-00 FD01 0501 000 1970 RENAULT 8200 367 488 8200 367 488T M724-SECURITY Best regards Sinisa |
Post Number: 2020 Registered: Aug-08
| Posted on Tuesday, October 13, 2009 - 06:30 am: |
Sinisa New member Username: Sikeey Post Number: 2 Registered: Oct-09 Posted on Tuesday, October 13, 2009 - 02:29 am: Hi Please help, I have a Renault Megane 2005 i disconnected my battery and now my Auto Radio is asking for the security code. Please find details below. RNRC 235 000 1970 RENRCW 230-00 FD01 0501 000 1970 RENAULT 8200 367 488 8200 367 488T M724-SECURITY Best regards ====================== Duplicate request! Multi-posted requests are ignored on this forum as they are both timewasting and annoying to the volunteers who read and answer these code calculation requests.. If you are that impatient for your code then try an online Decode Service who will supply your code by return.
