Home > Message Board > Car Audio > Security Systems > Viper 350hv problems
Author Thread: Viper 350hv problems
Username: Matt93
Iowa
Hello. I'm not sure what happened, but now my car alarm is no longer working. The blue security led is constantly on whether the car is on or not. I can lock and unlock the car with the transmitter but i've tested the alarm by opening the door from the inside and it doesn't work. How can i fix this? Where can i find a code book? The manual doesn't tell you how to program it.
Username: Matt93
Iowa
I figured it out. I somehow unknowingly disabled the alarm system by pressing a certain combination of buttons on the transmitter with the passenger door open.
I had to open the passenger door, press the lock button, press the aux button, and press the lock button again and now it is working perfectly again.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Security Systems > Viper 350hv problems [ « Previous ] [ Next » ]
