Home > Message Board > Car Audio > Amplifiers > 2 Kicker L7 10in, need amp help!
Author Thread: 2 Kicker L7 10in, need amp help!
Username: Juggalorj
Hi, my friend just sold me 2 kicker L7 10in in a ported box, and now I need an amp. My cousin has a Coustic 600se, would that be sufficient to use on these subs?
I've been told I should try to get a 1000watt amp instead of using the Coustic, any suggestions?
Username: Bonhamd
Traverse City, MI
Post Number: 1906
im not familiar with that amp - but it looks to be low end...
what voice coils do your L7s have?
what kind of vehicle is this going in?
Username: Juggalorj
The kickers are going in a 1999 Sonata, but I'm not sure about the voice coils, do you know how I would check?
Username: Juggalorj
I've been researching for a while now trying to figure out how to tell, I couldn't find any single voice coils for the L7s, so I don't think they come with single coil
Username: Bonhamd
Traverse City, MI
Post Number: 1907
they are either dual 2s or dual 4s
either measure your impedence with a digital multimeter or take the speakers out of the box and see what they say on them (where the wires connect to the speaker...
follow the link below:
http://www.car-stereos-online.com/products/kicker/pics/KICKER_SOLOBARIC_12L7_LAR GE.jpg
see where the blue-ish color is? it will tell you what your voice coils are right there
Username: Insearchofbass
York, Pennsylvania
Post Number: 12509
The coustic is a low end amp....what is your budget for a amplifier.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Amplifiers > 2 Kicker L7 10in, need amp help! [ « Previous ] [ Next » ]
