Home > Message Board > Car Audio > Security Systems > Viper 160XV Starter Kill (Cutting Sta...
Author Thread: Viper 160XV Starter Kill (Cutting Starter Wire)
Username: Jailerx
Hello, I am putting a Viper remote start (160XV) on my old 94 Cavalier. I am not crazy at all about cutting the starter wire fir the starter kill portion of the system. Since the car is so old, I am not really worried about someone trying to steal it. Is there a way to get around cutting the starter wire if you do not need to have starter kill active? I spoke with a rep at Viper who wouldnt go into install stuff too deeply with me but indicated that I would just connect the + starter wire to the vehicles uncut starter wire. Is that correct? I wanted to verify this before I went and messed up electronics.
Username: Sergdanilyuk
Farmington, MN
Yes you can do it. There will be no longer antigrind and starter kill work
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Security Systems > Viper 160XV Starter Kill (Cutting Sta... [ « Previous ] [ Next » ]
