Thread: What relativly cheap amp should I buy? 2x12"alpineType-S's |
Bronze Member Username: Cod1989
Allen Park,
MI
Post Number: 15 Registered: Jun-09
| Posted on Sunday, September 27, 2009 - 12:05 pm: |
Hello everyone, I was wondering if you could help me decide which amp I should buy to run 2x 12" Alpine Type S's . I'm hoping I won't have to spend over 200 dollars but any suggestions work. And also, how should I wire it? Thanks for your input. |
Silver Member Username: 2000celica
Roanoke,
VA
U.s.
Post Number: 173 Registered: Jan-08
| Posted on Sunday, September 27, 2009 - 03:26 pm: |
are they dual voice coil and if so what ohm are they? 2 or 4 ohm? |
Allen Park,
MI
Post Number: 16 Registered: Jun-09
| Posted on Sunday, September 27, 2009 - 04:10 pm: |
•12" subwoofer with dual 4-ohm voice coils •Kevlar®-reinforced pulp cone with aluminum finish •3/4" Santoprene rubber surround •stamped steel basket •frequency response: 26-1,000 Hz •power range: 50-300 watts RMS (150 watts per coil) •peak power handling: 900 watts •sensitivity: 87 dB Has anyone ever heard of a 1,000 Watt Black Memphis Amplifier? my boy was going to sell it to me for 100 bucks, I was going to buy it because it's in my price range but i've never heard of the company before and i can't find it online. its not memphis car audio so im not sure. |
Allen Park,
MI
Post Number: 17 Registered: Jun-09
| Posted on Sunday, September 27, 2009 - 08:23 pm: |
The brand name of that amplifier was actually Blackmore Is it useable for my setup? Info: Car amplifier boasts a maximum power of 1000-watts. Audio device features a variable bass boost control. Mosfet 2 channel amplifier. RMS power 300W x 1 at 0.01 THD. 4 ohms. Variable low pass crossover. Fixed high pass crossover. Remote subwoofer level control. Chrome plated RCS inputs. Variable gain control. LED power and protection indicators. Signal-to-noise ratio: better than 103 dB ...Thats all I could find on it. He also has this one... http://cgi.ebay.ph/NEW-FORMULA-2-CHANNEL-CAR-AMPLIFIER-1000-WATT-AMP-2009_W0QQit emZ220452529454QQcmdZViewItemQQptZCar_Amplifiers?hash=item3353fea52e&_trksid=p46 34.c0.m14 are either of these useable with my subs for about a month until i can get an aq1200d? |
Roanoke,
VA
U.s.
Post Number: 174 Registered: Jan-08
| Posted on Sunday, September 27, 2009 - 08:58 pm: |
The subs can hold 300 rms each so shoot for an amp that is stable at 1 ohm and that will do 600 rms. You wouldnt need a aq 1200 d, thatd be twice the power you would need for these subs. A good amp to do 600 rms shouldnt cost you too much at all. |
Allen Park,
MI
Post Number: 18 Registered: Jun-09
| Posted on Sunday, September 27, 2009 - 10:50 pm: |
yea i know but ill be upgrading to 2x 12" re audio d4 se's |
Roanoke,
VA
U.s.
Post Number: 176 Registered: Jan-08
| Posted on Monday, September 28, 2009 - 09:04 pm: |
AQ 1200 or Md.1d, as well as any other good 1200 rms x 1 amp. |
Platinum Member Username: Insearchofbass
York,
Pennsylvania
Post Number: 12324 Registered: Jun-04
| Posted on Tuesday, September 29, 2009 - 11:49 pm: |
Dont buy the md1d. |
