Thread: Component speakers |
New member Username: Newy_23
Post Number: 1 Registered: Sep-09
| Posted on Saturday, September 26, 2009 - 06:55 pm: |
i wanna spend about 150$ on component speakers, what would be the best set for the buck? CL-61A/TW-24 - CDT Audio Classic 6.5"? or a set of memphis? any recommendations? any 2 channel amps that are good but not to expensive? |
Bronze Member Username: 813thumper
Tampa,
FL
United States
Post Number: 22 Registered: Sep-09
| Posted on Sunday, September 27, 2009 - 11:24 pm: |
I have a pair of Diamond D3 components in the back of my car and they sound really nice. They don't cost too much either, but I bought mine about a year ago. |
Silver Member Username: Johammbass
IRL
Post Number: 772 Registered: May-06
| Posted on Saturday, October 03, 2009 - 11:16 am: |
You can get 3 of these: http://www.argos.ie/static/Product/partNumber/5134768/c_1/1%7Ccategory_root%7CHo me+entertainment+and+sat+nav%7C14573554/c_2/2%7Ccat_14573554%7CHome+audio+and+hi -fi+systems%7C14573555.htm and if you install them correctly, then the sound will be very nice, you don't even need a sub. And if you can get a really long mains cable then you don't even need an amp, just plug them in at your house and drive as far as the cable lets you. |
