Thread: C3 CD Player |
New member Username: Justin_uk7777
Post Number: 1 Registered: Sep-09
| Posted on Saturday, September 26, 2009 - 09:10 am: |
Can anyone help? I've just just brought CD player for my C3, it works fine but I get a loud bleeping noise, I guess that I need to pair the Cd player with car, 1st of all how do I that, and if I need a code where do I get it from. |
Gold Member Username: Regrooster
Post Number: 1921 Registered: Aug-08
| Posted on Saturday, September 26, 2009 - 11:41 am: |
Quote the player MAKE+MODEL plus ALL the NUMBERS+LETTERS on ANY LABELS , BARCODES or STAMPED IN THE METAL CASING |
Post Number: 2 Registered: Sep-09
| Posted on Sunday, September 27, 2009 - 12:52 am: |
Hi, thanks 4 replying. plz see the info you require CLARION MODEL PU-2471(J) 286-9487-45 CE CLARION RD3-01 96552632 XT serial no: CL054242081831J stamped on side of unit: H4091004C theres a no stamped looks like under a grill: T473008416B |
Bronze Member Username: Kelly123
Post Number: 11 Registered: Jul-08
| Posted on Sunday, September 27, 2009 - 10:33 pm: |
in fact, you don't pair your cd player, you can add install a charmaker digital music changer in your can, it will complate replace your factory cd player, it delivers CD-quality sound directly into the factory sound system via the CD changer port, without the loss of sound quality that occurs with existing cassette and FM transmitter solutions. Directly connect to your car radio by a vehicle specific cable harness, and directly control from car stereo panel or steering wheel, user can enjoy the digital music (MP3/WMA) what you like in your car only need a SD card or USB disk, and there also is Aux input for external audio sources, Auxiliary devices such as MP3 players, Portable DVD players, Minidisk Player, handheld gaming systems, notebook computers and IPHONE can be added to the OEM radio while delivering optimum sound quality. Hope this will help you. http://www.car-cd-changer.net |
Post Number: 1930 Registered: Aug-08
| Posted on Monday, September 28, 2009 - 10:18 am: |
justin Edwards New member Username: Justin_uk7777 Post Number: 2 Registered: Sep-09 Posted on Sunday, September 27, 2009 - 12:52 am: Hi, thanks 4 replying. plz see the info you require CLARION MODEL PU-2471(J) 286-9487-45 CE CLARION RD3-01 96552632 XT serial no: CL054242081831J stamped on side of unit: H4091004C theres a no stamped looks like under a grill: T473008416B =================================== The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing. (There are usually two barcodes on one label. The one required is the lower one ) If not then it will only be available from your Main Dealer or a Decoding Service |
