Home > Message Board > Car Audio > Head Units > Siemens vdo cdr 2005 player in 2005 c...
Author Thread: Siemens vdo cdr 2005 player in 2005 corsa need code
Username: Cdr_vdo_2005
hi i have a 05 corsa with siemens vdo cdr 2005 player in it i have the serial number gm020543417164 and i need the code because its in safe mode thanks in advance
Username: Regrooster
Post Number: 1923
Unfortunately the majority of SIEMENS/VDO codes (including yours) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
thanks for the help mate ill try that
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Head Units > Siemens vdo cdr 2005 player in 2005 c... [ « Previous ] [ Next » ]
