Thread: Renault Clio Radio Tuner List, unlock the code |
New member Username: Chiuchoi
Post Number: 1 Registered: Sep-09
| Posted on Friday, September 25, 2009 - 12:31 pm: |
Hello, I would appreciate for help to find the code to unlock my cd player "Tuner List" Renault Clio. I need the code: Model No.: 22DC239/62P T0I805 RN239F20051571 Prod No. FD000280051571 Bar code: 8200041271TI805 Many Thanks. Chiuchoi |
Gold Member Username: Regrooster
Post Number: 1918 Registered: Aug-08
| Posted on Friday, September 25, 2009 - 02:03 pm: |
Try code 8315 |
Post Number: 2 Registered: Sep-09
| Posted on Saturday, September 26, 2009 - 02:34 am: |
Hello Reg Rooster, thanks for the prompt reply. But I can't enter the number 8, because it is only to find the number 1 to 6 on the panel. Can you please give me an other one. Thank you. Chiuchoi |
Silver Member Username: Decode
POLAND
Post Number: 279 Registered: Jan-09
| Posted on Saturday, September 26, 2009 - 10:53 am: |
Chi-Duc Nguyen---> http://www.radio-code.co.uk/code-entry-help.php |
Post Number: 1922 Registered: Aug-08
| Posted on Saturday, September 26, 2009 - 11:44 am: |
=================================== Philips Renault Code Entry Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [¬ ] button for up to 10 seconds to store the code =================================== |
New member Username: Greenman55
Colchester UK
| Posted on Monday, September 28, 2009 - 03:34 pm: |
Hi, I hope you can help - My garage disconnected the battery on my clio but the radio code I have does not work. The model is 22DC278/62B. T0I379 RN278F10027550 Prod FD010240027550 Bar code 8200057681TI379 Thanks Greenman |
POLAND
Post Number: 293 Registered: Jan-09
| Posted on Tuesday, September 29, 2009 - 07:18 am: |
Philip Rand---> Sorry...not in my database. Try emailing radiocodeservice@gmail.com to see if they can help |
New member Username: Borjan
Post Number: 2 Registered: Oct-09
| Posted on Monday, October 05, 2009 - 04:25 pm: |
Hello! I'm looking for code of my Renault Clio (2001) radio. model no: 22DC259/62F TOR812 RN259F10338530 prod no: FD0501080338530 8200029539TR812 8200/029/539 Thanks! |
Post Number: 1978 Registered: Aug-08
| Posted on Monday, October 05, 2009 - 06:08 pm: |
borjan New member Username: Borjan Post Number: 1 Registered: Oct-09 Posted on Monday, October 05, 2009 - 04:11 pm: Hello! I'm looking for code of my Renault Clio (2001) radio. model no: 22DC259/62F TOR812 RN259F10338530 prod no: FD0501080338530 =============================== Duplicate Request Why post the same request in different threads ? Multi-posted requests are ignored as they are both timewasting and annoying to the volunteers who read and answer these code calculation requests.. If you are that impatient for your code then try an online Decode Service who will supply your code by return. |
Post Number: 3 Registered: Oct-09
| Posted on Tuesday, October 06, 2009 - 01:56 am: |
I'm not impatient just wanna make sure im on right topic, because you have a lot of them with same subject. Thx anyway. |
New member Username: Mihaelt
Post Number: 1 Registered: Nov-09
| Posted on Wednesday, November 25, 2009 - 04:16 am: |
Hello, I would appreciate for help to find the code to unlock my cd player "Tuner List" Renault Megane. I need the code: Model No.: 22DC279/62T T0U503 RN279F20200504 Prod No. FD0302180200504 Bar code: 7700434423TU503 Many Thanks. Mihael |
Post Number: 2355 Registered: Aug-08
| Posted on Thursday, November 26, 2009 - 04:13 am: |
Duplicate Request ...Already answered Why post the same request in different threads ? |
