Home > Message Board > Car Audio > Head Units > Need help with pioneer deh-2900 deck!!
Author Thread: Need help with pioneer deh-2900 deck!!
Username: Bmx4life54321
okay so this deck is really makin me mad, i plugged it into my frends wiring harness using all his wiring and the plug that came with his deck. my deck turned on. i cannot get my deck to turn on with the harness that came with it. it has all the correct speaker wires but then has a yellow and black wire that i have no idea what it does, an illuminate wire. then the remote wire, ground, 12v constant and blue and white power antenna wire. i hooked up the yellow constant, red remote, and black ground wire properly. the deck will not power up. does the yellow with black striped wire need to be hooked up to something?? o the orange and white illuminate wire? i used to work for fire dog installing car audio and ive never had a problem like this before. my friends pioneer deck is newer and that harness worked just fine. anyone got any ideas. or a schematic of what wire is supposed to go where on the deck?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Head Units > Need help with pioneer deh-2900 deck!! [ « Previous ] [ Next » ]
