Thread: Ohm problem amp is not doing one ohm like it suppose too, only does 4 |
New member Username: Qulin
Qulin,
Missouri
United states
Post Number: 7 Registered: Sep-09
| Posted on Tuesday, September 22, 2009 - 11:50 pm: |
ok i have a hifonics bxi1610 4ohms-500, 2ohms-1100 and 1ohm-1600 its on a 2ohm dual voice coil 12'' L5 when i have it wired for 1 ohm, positive to positive, negative to negative you can barley feel it moving but when i have it hooked up 4ohm it hits hard but i know my sub can handle way more hifonics dont put out all there rating so i need to know why it aint working at 1ohm |
Gold Member Username: Somedonniedude
Illinois
Braaap MX
Post Number: 2762 Registered: May-07
| Posted on Thursday, October 01, 2009 - 11:25 am: |
What gauge wire do you have for power and ground? Does your ground have a good connection (aka proper area, sanded, secure). |
New member Username: Drbizerk
Okc,
Ok
U.s.
Post Number: 8 Registered: May-09
| Posted on Friday, October 16, 2009 - 03:15 am: |
use a multi meter to make sure its actually @ 1ohm |
