Home > Message Board > Car Audio > Amplifiers > Power wire
Author Thread: Power wire
Username: Qulin
Qulin, Missouri
United states
will it hurt if i run 8 gauge wire for alittle bit intill i get 4 gauge, it calls for 4 gauge but it wont hurt my amp if i run 8 gauge for like a week will it?
Username: Nd4spd18
Philadelphia, PA
Post Number: 10673
Not only will it make the amp clip its extremely dangerous if the wire isnt fused properly... it will keep blowing the fuse, and if you put a bigger fuse in it thats asking for a fire.
Username: Qulin
Qulin, Missouri
United states
alright thanks
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Amplifiers > Power wire [ « Previous ] [ Next » ]
