Thread: Does anyone know how overrated hifonics are on there amps? |
New member Username: Qulin
Qulin,
Missouri
United states
Post Number: 2 Registered: Sep-09
| Posted on Tuesday, September 15, 2009 - 11:08 pm: |
bought a 1600 watt rms hifonic today and wonderin if anyone knew true power |
New member Username: Xxemoxx
Hermosa beach,
Cali
Post Number: 3 Registered: Sep-09
| Posted on Thursday, September 17, 2009 - 12:02 pm: |
look at the fuse on the amp, if its 20amps then its generally about 200 watts, etc. Hifonics before maxxsonics bought them used to be very ok amps for the money, but i am pretty sure the 1600 watt rating is at 1 ohm for 10-15 sec. on a test bench and the true 4ohm rms rating is significantly smaller., Good rule of thumb it should cost between .75-$1.00 a watt for good true rms power. |
Qulin,
Missouri
United states
| Posted on Thursday, September 17, 2009 - 03:27 pm: |
ok well i just have one l5 12'' solo but i wanted to get a good amp so when i get a l7 i can turn that baby up and should be ok it says 1100 at 2 ohm 1600 and 1ohm and has two big 80 amp fuses, now to put my sub on a 2ohm load its dual 4ohm so i need to put negative to positive on one side then negative to positive on other then run negative and positive to my amp right? |
Bronze Member Username: Jbpitt
Pittsburgh,
Pa.
Usa
Post Number: 75 Registered: Jul-09
| Posted on Thursday, September 17, 2009 - 04:30 pm: |
http://www.the12volt.com/caraudio/woofer_configurations.asp |
Platinum Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 10669 Registered: Jul-06
| Posted on Friday, September 18, 2009 - 01:39 am: |
You asked and you shall recieve http://forum.ecoustics.com/bbs/messages/4/542894.html " Good rule of thumb it should cost between .75-$1.00 a watt for good true rms power. " Need to get with the times there... the technology is not that expensive anymore |
Bronze Member Username: Xxemoxx
Hermosa beach,
Cali
Post Number: 14 Registered: Sep-09
| Posted on Friday, September 18, 2009 - 02:14 pm: |
M.S. you keep trying to rip on me, and I know there are plenty of D class amps out now that can preform at 1-2ohm loads with very high wattage ratings, but I am talking about a true 4ohm rms load, @ 12 volts. Sure you can bridge stuff down and lower the S.Q. ability to make more power at a lower ohm load and if you just want SPL levels thats fine, but not everyone wants annoying dirty loud bass. I am more an S.Q. fan, and do realize different strokes for different folks, but you don't have to go around being an a** just because you disagree with what someone else likes or believes. BTW its not the technology that is expensive, its using the good materials, copper and gold are more expensive then they have been in 7 years, so now companies are cutting corners even the bigger name companies are changing production techniques, and skimping where it counts therefore lowering the quality of there product. MB Quart is a giant example of this, from what I know diamond sadly is headed that direction too. It happened to Fosgate 5 years ago until they got there stuff together and realized that had made a huge mistake and started to bring themselves back up.. My point being just because technology is cheaper do not mean other factors are not playing a role in cost, or quality of construction. |
Gold Member Username: Snowball123
West Allis,
WI
Post Number: 3110 Registered: Oct-07
| Posted on Friday, September 18, 2009 - 06:07 pm: |
The usual output from the Hifonics amps is usually about 80% of rated power, or at least thats the number I always stuck with. I heard that the newer lines on the Hifonics amps put out rated, but never really searched around for bench tests. |
Qulin,
Missouri
United states
Post Number: 4 Registered: Sep-09
| Posted on Sunday, September 20, 2009 - 10:44 pm: |
will it matter if i run 8 gauge power and ground wire for alittle bit as long as i dont turn it up to loud cause it calls for 4 gauge |
Bronze Member Username: Sonic_assault
Katy,
Tx
Usa
Post Number: 29 Registered: Oct-07
| Posted on Monday, September 21, 2009 - 12:00 am: |
im about to buy a hifonics 1208d claims 1200 rms into 1 ohm .... im pushing 2 diamond audio D6 15's. i have already tryed this amp on them and i was extremley impressed...it pushed them as hard as the massive audio 1500.1 i had on them .... its a used amp that im getting for 120$$ any suggestions?? |
