Home > Message Board > Car Audio > Accessories > Need code for Mercedes Audio 10 CD (A...
Author Thread: Need code for Mercedes Audio 10 CD (Alpine MF2199)
Username: Erblis
hi all
A1708200186
model no:MF2199
S/no. AL 2199 W 10 55628
Username: Regrooster
Post Number: 1842
Try code 33666
Username: Erblis
Hello, this code was not correct: (
Post Number: 1848
Then the code will only be obtainable from the Merc Main Dealer or a Decoding service
Username: Erblis
but is possible calculate code
Post Number: 1853
The code will not be available for free (using the serial number) from anywhere on the Internet
The Main Merc Dealer will have to look your serial sumber up on the original factory database (providing they are willing to do it!)..If your radio has been recoded in the past to a different number then you will NOT get a refund !
The best option is to take it into a Decode Service or your local Car Radio /Audio Store who will connect it to a laptop and read / recode the memory chip (EEPROM)
This only takes a few minutes and should not be too expensive
Username: Erblis
my friend, I am in Albania, and it is impossible to do so as you say here because there are no such services, so I'm looking at this way. Sorry for my English
Post Number: 1860
Then it is unlikely that you will be able to obtain the code for this radio.
More economical to buy another with a code
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Accessories > Need code for Mercedes Audio 10 CD (A... [ « Previous ] [ Next » ]
