Home > Message Board > Car Audio > Amplifiers > Soundstream vs. alpine
Author Thread: Soundstream vs. alpine
Username: Hockeytoker
Post Number: 91
ok so im going to either be gettin these speakers
http://www.woofersetc.com/p6201/CTX65CS--Image-Dynamics-65"-Component-Speaker-System.htm
or these
http://www.sonicelectronix.com/item_17121_Precision+Power+PPI+356CS.html?utm_sou rce=froogle&utm_medium=organic&utm_campaign=froogle#
and im wondering which amp would be good for either of these speakers.
ppl have told me either this sound stream amp
http://www.woofersetc.com/p6750/TRX4300--Soundstream-4-Ch-300-Watt-Amplifier.htm
or this one
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19262
i'd be bridging either of these amps.
any other amp recommendations?
thanks!!!!!
Username: Xxemoxx
Hermosa beach, Cali
P.P.I. does make some nice components but the tweeters for me just are not bright enough, look on ebay for the price you want to spend you can get a nice set of Boston sl60's or if your lucky a good set of the german made mb quart pce 216's Both way better then the PPI's.
Also ADS and the HCCA orions are very nice with a good solid mid-bass driver.
The alpine amp you have is a great choice for the price amazing, just remember you are buying S.Q. quality components so you want to get an amp that will provide clean signal at 4ohms. Comp's at 2 ohms just sound awful.
Anyway just some friendly advice and good luck.
Username: Crave420fubar
Post Number: 7
Sound Stream is known for better clearity and alpine well it's alpine. Note the "Tri-guard amplifier protection" this is power surge and thermal overload protection that the alpine will not offer also most alpine do not use dual or tri-mode (2 Ohms front speaker and 4 Ohms rear speaker = dual mode) the SoundStream you picked hands down is better than the alpine. for these two reasons.
P.S.
I learned that Alpine does not do dual mode the hard way :-( the poor amp (MRP-F250) was so hot that I could not even touch it for 30 mins after it fried.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Amplifiers > Soundstream vs. alpine [ « Previous ] [ Next » ]
