Thread: Alternator help..plz |
Bronze Member Username: Wackzirth88
K-town,
Il
U.S.
Post Number: 81 Registered: May-09
| Posted on Saturday, September 05, 2009 - 07:55 pm: |
i only have a stock 110 amp alternator and stock battery, im lookin into a ed nine.1, which says it has a max current draw of 130 amps. does that present a issue? plz explain |
Silver Member Username: Vivi2000
Lansing,
Mi
Post Number: 255 Registered: Aug-07
| Posted on Saturday, September 05, 2009 - 10:18 pm: |
You will most likely not run into any problems with that, a constant 130a draw would only happen if you are playing straight up sine waves or are clipping the amp. My car has 2 amps with a total amp rating of 130a and a 110a alternator and it plays and runs fine. Remember that when playing music you will probably not reach the peak rms of the amp for more than a short while because music is dynamic. |
K-town,
Il
U.S.
Post Number: 82 Registered: May-09
| Posted on Sunday, September 06, 2009 - 01:41 am: |
alright thanks, gonna take ur advice and get it while its on sale |
