Thread: Code? for renault scenic 2001 y reg(young lady in distress) |
New member Username: Susan7
Post Number: 1 Registered: Aug-09
| Posted on Friday, August 28, 2009 - 11:42 am: |
i took my bog standard factory fitted radio out and put a brill mini disc player in.i stuck a sticker on the radio with the code on it which the garage i purchased it from told me.i have had some nice person break in and steal my brill m/d player so now have to put original one back in.only trouble is the sticker came off and i cant find it any where these are the numbers on it if anyone can help me out i would be very gr8 full. 7700434424tt762 0205939 7700 434 424 RN259F10205939 MODEL NUMBER-22DC259/62P PRODUCT NUMBER-FD0401010205939 |
Gold Member Username: Regrooster
Post Number: 1733 Registered: Aug-08
| Posted on Friday, August 28, 2009 - 03:47 pm: |
Try code 6231 |
Post Number: 2 Registered: Aug-09
| Posted on Friday, August 28, 2009 - 03:58 pm: |
ive tried that but the last digit still flashes.does that mean its not the right code or do i press something else after the 4 digits? thanks  |
Post Number: 1741 Registered: Aug-08
| Posted on Friday, August 28, 2009 - 07:02 pm: |
Philips Renault Code Entry Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to store the code |
Post Number: 3 Registered: Aug-09
| Posted on Friday, August 28, 2009 - 08:09 pm: |
ive just done it at 1am lol.thank you for explaining to me. it was the holding in of the button i didnt do. yor a star.cheers.x |
