Thread: 2009 Ford Explorer Navigation |
New member Username: Rcarteraz07
Frederick,
MD
Post Number: 1 Registered: Aug-09
| Posted on Monday, August 24, 2009 - 02:26 pm: |
I am looking for the Navigation unit that they use in the 2009 Ford Explorer or one that will work but looks like Factory and uses all the features of my explorer...i.e. steering controls, line in, reverse sensing and I would also like to get bluetooth to be incorporated too. |
Bronze Member Username: Susiehe
Post Number: 16 Registered: May-09
| Posted on Friday, August 28, 2009 - 01:17 am: |
Maybe you could have a look at ZorroGPS to see if it meets your need. It is specialized in GPS navigation. |
New member Username: Limlin
Post Number: 4 Registered: Aug-09
| Posted on Monday, August 31, 2009 - 05:03 am: |
Yes, ZorroGPS has a free trial about one week. You can try it first and then decide whether it's fit for you or not. |
