Thread: Citroen Saxo radio code |
New member Username: Cleo178
Post Number: 1 Registered: Aug-09
| Posted on Thursday, August 06, 2009 - 12:35 pm: |
Hello, i've lost the radio code of my car. Can you help me? Car : Citroen Saxo Radio : System Audio 2014 RDS Serial N° VF7S0CDZF56389499 Thank you ! |
Gold Member Username: Regrooster
Post Number: 1584 Registered: Aug-08
| Posted on Monday, August 10, 2009 - 09:57 am: |
Insufficient information. Please post all the letters+numbers found on the radio labels+stamped in the metal casing |
New member Username: Sezmo27
Post Number: 1 Registered: Oct-09
| Posted on Wednesday, October 28, 2009 - 01:17 pm: |
i didnt recieve radio code with car, and battery died car - citroen saxo radio serial no. CL040210712580 model no. PU-2294B(D) please help thanks |
Post Number: 2164 Registered: Aug-08
| Posted on Wednesday, October 28, 2009 - 02:58 pm: |
sarah hallworth New member Username: Sezmo27 Post Number: 1 Registered: Oct-09 Posted on Wednesday, October 28, 2009 - 01:17 pm: i didnt recieve radio code with car, and battery died car - citroen saxo radio serial no. CL040210712580 model no. PU-2294B(D) ===================================== Your radio is made by Clarion and the only code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing. If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) |
