Thread: Garmin nuvi 760 bluetooth |
Bronze Member Username: Saado7
Post Number: 36 Registered: Dec-07
| Posted on Saturday, August 01, 2009 - 09:50 am: |
my unit freez up when i try to enable bleutooth any ideas on how to fix this problem?? |
New member Username: Medic2586
Post Number: 1 Registered: Jul-08
| Posted on Thursday, September 24, 2009 - 12:43 pm: |
i have an oem nav radio in my 2006 f150 that i got on ebay. everything works except the subwoofer is not enabled. radio is 7L3T-18K931-DB, S/W 3.040000 when i do the 3-6 diagnostics, it shows up that the subwoofer is "not enabled". local ford dealer, 2 of them, can't program it or don't know how...can anyone help? i see i can send them off but i don't want to do that....have a big gaping hole in the middle of the dash.....help please |
Bronze Member Username: Limlin
Post Number: 16 Registered: Aug-09
| Posted on Monday, September 28, 2009 - 02:51 am: |
Maybe you can go to the offical website for help. Or get in touch with the coodinator. They are helpful. |
