Home > Message Board > Car Audio > Accessories > Whats a good way to hide your power w...
Author Thread: Whats a good way to hide your power wire and your rca cable?
Username: Tb75947
Pa
United States
Post Number: 11
Im running power wire and rca cables back to my subs in the trunk of my car. How do i make it look professional and hide the wiring nicely?
Username: Subfanatic
Ky
Post Number: 4837
on the side of your car your battery is on run your power wire down the carpet on the inside of the car. you may have to drill a small hole in your firewall and place a grommet in it to protect the wire.
Run the RCA's down the opposite side of the car from your head unit to prevent road noise or alternator whine.
By the way to hide the wires either go the long way and take your seats out and run it completely safely under the carpet or pull the trim off the inside of the doors and pull the carpet up a little and shove it in haha.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Accessories > Whats a good way to hide your power w... [ « Previous ] [ Next » ]
