Thread: Alpine SPR-17C good speakers? |
Bronze Member Username: Hockeytoker
Post Number: 21 Registered: Jul-09
| Posted on Thursday, July 16, 2009 - 03:37 pm: |
im gonna have type r subs so i fugured these would be good to go along with them. if these are good an i get them would i need an amp? especially if i get 2 for the front and 2 for the back? if so what amp would be good? haha stupid questions but these come in pairs of two right? http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17562 |
Silver Member Username: Exige
CDT, Audiopulse Dealer
Post Number: 788 Registered: Nov-07
| Posted on Friday, July 17, 2009 - 04:02 am: |
You can do much better than Type R's. What's your budget? An amp is always recommended as it will drastically improve the sound of your speakers. Forget getting a pair in the front and a pair in the back. It's a waste of money, you don't need rear fill. Instead take the money you were going to spend on rears and put them towards a better front set. And yes, speakers come in a pair. Also decide if you just want coaxials or if you want to get components. Components will sound much better. |
Post Number: 24 Registered: Jul-09
| Posted on Friday, July 17, 2009 - 04:34 am: |
Budget prob 150-200 tops what would you recommend?? |
Post Number: 789 Registered: Nov-07
| Posted on Friday, July 17, 2009 - 11:45 am: |
Figure out the rest of the stuff mentioned: are you gonna use an amp? Do you want to run comps or coaxials? |
Post Number: 25 Registered: Jul-09
| Posted on Friday, July 17, 2009 - 02:47 pm: |
Well if comps sound a lot better then those. And ya I most likely will get an amp. It would only need to put out like 500 watts rms wouldn't it? |
