Thread: Replacement Alt |
Gold Member Username: Jtown
Texas
Post Number: 3810 Registered: Mar-07
| Posted on Saturday, July 04, 2009 - 10:24 pm: |
So I've noticed my voltage is a bit low at idle, aka around 12.5v.....and it only gets worse on really hot days. I'm assuming it's going bad and I'll prob get re-tested sometime before summer is over. If I need a new alt, I was thinking of going a bit larger anyway. Right now I'm in between MCR and DB. At MCR I can get a 160amps max, don't know the idle, for $180 right now, prob $190 when I have the money. At DB I can get a 200amps max, 105amps idle alt for $220. My question, which is the better quality choice? Thanks in advance. |
Platinum Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 10552 Registered: Jul-06
| Posted on Saturday, July 04, 2009 - 10:46 pm: |
Both are good but get the DB. More power for the price. |
Texas
Post Number: 3813 Registered: Mar-07
| Posted on Saturday, July 04, 2009 - 11:05 pm: |
yeah that's really what I'm leaning toward. plus the 200amp alt could benefit me in the future once I start modifying to engine and the rest of the vehicle. |
Gold Member Username: Hdubb
Team Revolution
Post Number: 4179 Registered: Nov-04
| Posted on Sunday, July 05, 2009 - 09:48 am: |
i agree with m.s. justin |
Texas
Post Number: 3817 Registered: Mar-07
| Posted on Sunday, July 05, 2009 - 05:19 pm: |
thanks fellas |
