Thread: Ot crossfire vr2000d |
Silver Member Username: Kickerman
Post Number: 232 Registered: May-06
| Posted on Sunday, June 28, 2009 - 01:59 am: |
is $250 to much for a used one in ok condition |
Gold Member Username: Somedonniedude
Illinois
Braaap MX
Post Number: 2693 Registered: May-07
| Posted on Sunday, June 28, 2009 - 12:06 pm: |
That's a good price for any quality 2kw+ amp. The VR amps are suppose to be great amps. I'd snatch that thing up in a heartbeat. |
Platinum Member Username: Rovin
1 15 = 149.5 DBs ... Trinidad & T...
Post Number: 15160 Registered: Jul-05
| Posted on Sunday, June 28, 2009 - 12:29 pm: |
gr8 amp : get it ! ... |
Gold Member Username: Sinful_systems70
15 INCH WANG...
Post Number: 1281 Registered: Nov-06
| Posted on Tuesday, June 30, 2009 - 12:06 am: |
X3 if you don't want it, I'll take it! |
Silver Member Username: Poprocks
Post Number: 260 Registered: Mar-09
| Posted on Tuesday, June 30, 2009 - 12:50 am: |
Jump on it before someone else does. 2000RMS at 2ohm 12.5v |
15 INCH WANG...
Post Number: 1282 Registered: Nov-06
| Posted on Tuesday, June 30, 2009 - 01:12 am: |
where is it at? is it in working condition? |
Gold Member Username: Loc_out
SoCal
Post Number: 2944 Registered: Feb-05
| Posted on Tuesday, June 30, 2009 - 05:06 pm: |
If your able to post some pix |
Post Number: 233 Registered: May-06
| Posted on Tuesday, June 30, 2009 - 10:05 pm: |
yes its in working conditon and its local |
15 INCH WANG...
Post Number: 1284 Registered: Nov-06
| Posted on Tuesday, June 30, 2009 - 10:53 pm: |
Are you buying it? |
Bronze Member Username: Caraudioislikecrack
Post Number: 89 Registered: Nov-08
| Posted on Tuesday, June 30, 2009 - 11:27 pm: |
buy it i had 2 the older one with no fan and the newer one with a fan .they are good amps buy it n even if u dont use it ebay it u will get more than 250 |
