Home > Message Board > Car Audio > Subwoofers > Archive through July 12, 2009 > Pleaz help wit buyin new sub...
Author Thread: Pleaz help wit buyin new sub...
Username: Abubba7fan
Kicker cvx 4ohm 12" Sub vs. RE Audio ssx 4ohm 12". kicker = 750rms and re = 1000rms. i luv da kicker...but would re aud b better???
install in mi 2007 dodge charger...got a 1000w autotek sub amp. i have 4 re aud 6x9s and set of re aud tweets. got the 6.5 in kenwood flip/touch indash. pleaz help out wit ur advice, really appreciate ur input.
Username: Rideredder
Cornell, IL
Post Number: 1658
RE.
Username: Ctmike
Ct.
Post Number: 6767
better choice, going back to first grade and learning to spell. jesus, i feel dumber just reading that post.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 6882
for one there is no SSX.. there is an SXX.. and its DVC 2 or 4 ohm
and which Autotek amp.. they have a few 1000s
Diamond Member
Post Number: 23367
cut him some slack ctmike. maybe he just moved to the states from another country.
Username: Hittin1
TEAM REVOLUTION
Lake Charles...
Post Number: 3487
mean machine or street series autotek?
Username: Hittin1
TEAM REVOLUTION
Lake Charles...
Post Number: 3488
RE all the way btw
Username: Loc_out
SoCal
Post Number: 2940
let us know what amp you got. Would a 15 work for you? If it does look into the RE SX.
Repost...
I own a 2007 Dodge Charger and I am having a new audio system installed today. I am trying to decide between the Kicker CVX 12" subwoofer and the RE Audio SX 12" subwoofer, both subs are 4 ohms.
The Kicker subwoofer is similar to the L7 Solobaric, which I have installed in my Ford Expedition. And in my opinion it's the best subwoofer I have ever owned. I have had it for 3 years and never had a problem, still hits like new.
But I was thinking of going with the Kicker CVX 12" round in my car to get better overall sound quality (Tighter, crisper and cleaner) It is enclosed in a ported box, as is the RE Audio subwoofer.
What is the reputation for the RE Audio SX 12"? Why would it be better in your opinion than the Kicker? It's obvious that it has a louder RMS, but what about sound quality? Any suggestions would be much appreciated.
Other equipment:
*Kenwood KVT-514 In-Dash Multimedia DVD Receiver With 7" Motorized Screen
*RE Audio 1" Car Silk Dome Tweeters mounted at the top of my front door panels
*RE Audio 6x9's 3- way in front door panels (100 Watt RMS each...200 Watt RMS per pair
*RE Audio 6x9's 3-way in rear window shelf/tray (100 Watt RMS each...200 Watt RMS per pair.
MB Quart RAB1450 1 Channel 450 Watt Amp for Mids/Highs.
Autotek Super Sport 1 Channel 1500 Watt Amp for subwoofer.
Thanks for all of your help. I am so appreciative of your session schooling me in your previous posts. I've officially been served...LOL. j/k FYI: I posted my original question via my Blackberry cell phone if you care to know.
Thank you to all...i would be glad to reciprocate to your posts, too.
Username: Frkkevin
Team DLS
SuperNatural...
Post Number: 6883
Do you RE you won't regret it.. just get a box built to specs
.. but i mean you have room to run the 15".. why not do that?
Username: Craudi0
Post Number: 65
i have a RE SE 12", which is basically just a step down from the SX, and its sound quality is amazing, and it gets loud too. i had a kicker cvr, which i would think would somewhat be like the cvx, and it does real good on the higher and mid bass, but doesnt even come close to the RE in the lows. so it depends i guess on what exactly you are looking for
Username: Kingandsons07
TEAM REVOLUTION
Lincoln,NE
Post Number: 622
the RE SXs are great subs and with the right install it will blow you away how great it sounds
Username: Woofers4life
Lexington, Tennessee
Post Number: 106
yea round kickers hate lows but they will kill mids and upper. Lows in my opinion are wayyy better than gettin upper freq but i like the jaw rattling bass lol
Username: Craudi0
Post Number: 71
yep, and the re's upper and mids arent bad either, which is why the re in my opinion is much better :-)
Post Number: 107
yes that was what i was implying lol.
Thanks for the help...tested both before i made the deal. No doubt, the kicker hate the lows...RE sweeter lows.
Home > Message Board > Car Audio > Subwoofers > Archive through July 12, 2009 > Pleaz help wit buyin new sub... [ « Previous ] [ Next » ]
