Home > Message Board > Car Audio > Security Systems > Archive through July 17, 2009 > Need code for honda cd
Author Thread: Need code for honda cd
Username: Dikar
Please help need vode for honda radio
serial no: 97j22420
model 39100-s10-a000
thanks
Username: Regrooster
Post Number: 1442
HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any othermake.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service.
Home > Message Board > Car Audio > Security Systems > Archive through July 17, 2009 > Need code for honda cd [ « Previous ] [ Next » ]
