Home > Message Board > Car Audio > Speakers > 1993 Honda Prelude help!
Author Thread: 1993 Honda Prelude help!
Username: Bachman101
Post Number: 38
So my friend's wanting to upgrade his stock speakers in his, you guessed it, 1993 honda prelude. Using cruthfields "outfit my car" option there are very limited 6 1/2 that will supposedly fit, so i was wondering are these really all his options? there are only two component sets that crutchfield sells that will fit. Anybody have any experience with a 93' prelude?
Username: D2freak
Post Number: 37
post your message enough times?
find out what the stock holes are for the car.... you should have a ton of options, and crutchfield it's extremely expensive
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Speakers > 1993 Honda Prelude help! [ « Previous ] [ Next » ]
