Home > Message Board > Car Audio > Speakers > ••••> Best sub(s) for my 03 eclipse s...
Author Thread: ••••> Best sub(s) for my 03 eclipse spider (small trunk)
Username: 03eclipse
so like the title says i have an 03 Mitsubishi eclipse convertible, the trunk is small only around 15-16" deep and the and at the opening its only around 35" x 15", it gets bigger once you get in the trunk but the mouth/opening is the smallest part.
i was thinking of getting 1 10" JL W6 with the HO box or the W7 in the wedge box. i don't think i can get the 10"w7 HO box in the trunk
then i'm going to buy this amp (Phoenix Gold XENON X600.1) to match it i think it will be a perfect match cause it has the Xe.load™: optimized for any impedance load i can't afford a bigger amp yet but i will upgrade it one day
http://www.savinglots.com/lotprod.asp?item=X600.1
i just want something that going to slam even though i have a coverable
let me know if the w6 ho is better then a w7 wedge or whatever
Username: 03eclipse
oppps wrong spot please delete this mods
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Speakers > ••••> Best sub(s) for my 03 eclipse s... [ « Previous ] [ Next » ]
