Home > Message Board > Car Audio > Head Units > Archive through August 05, 2009 > Need radio code for jensen vm9412
Author Thread: Need radio code for jensen vm9412
Username: Tappedout247
Help! I bought a used car with a jensen vm9412 and i need to find out how to get the password to be able to use my system? Any ideas? thanks! Need tunes fast!
Username: Regrooster
Post Number: 1151
I don`t recognise the numbers.
Please quote all the letters+numbers on any barcodes, labels or stamped in the metal casing
Username: Jaackdeth
United States
Post Number: 786
Did you contact the person you bought the car from? I am selling that same head unit, try 123456, if that doesn't work, try it 654321, that is what I did to get mine to work. Hope this helps.
Home > Message Board > Car Audio > Head Units > Archive through August 05, 2009 > Need radio code for jensen vm9412 [ « Previous ] [ Next » ]
