Thread: Speaker placement |
Bronze Member Username: D2freak
Post Number: 13 Registered: May-09
| Posted on Sunday, May 31, 2009 - 11:57 pm: |
I drive a 4 door grand am, planning to cut a 15" sub into the back seat, build my box accordingly. I've seen mixed opinions about speaker location and such, but I plan to build at least one set of pods on my doors, should I put a second set of components in, say the back? or another location? I figure if they're in back I won't really be able to hear them, but it is nice to have that extra sound. Any advice on this would be helpful this is the speakers I plan to use, just need to know how many sets to get (the sub is a 1999 hcca 15d, so I'm sure especially where I'm putting it, it will be hella loud) http://www.dealercostcaraudio.com/orionhcca62.aspx |
Gold Member Username: Carguy
Post Number: 6958 Registered: Nov-04
| Posted on Monday, June 08, 2009 - 11:49 pm: |
Unless you plan on spending lot of time in the rear seats, no need to waste money there. Save the money and buy a better set of components for the front. 75w isn't much. Get 100w rms - 150w rms. |
