Home > Message Board > Car Audio > Security Systems > Radio Codes For Free > Archive through March 28, 2009
Author Thread: Archive through March 28, 2009
Username: Diefex
Hello,
1996 BMW 318ti series
Philips Business RDS
model: 65.12-8 374 583
Serial:PH7850t1136490
KW 25/96 Index:00
22DC785/23F
WA009625
Barcodes (running right above the face)
9022 217 8523300
003 9625 435190
that is pretty much all of the numbers that were on the sticker, hopefully that helps.
Username: Regrooster
Post Number: 455
Rob Duncan
Username: Diefex
Posted on Tuesday, February 03, 2009 - 04:21 pm:
Hello,
KW 25/96 Index:00
22DC785/23F
WA009625
9022 217 8523300
003 9625 435190
Sorry , the required Serial Number PH7850t1136490 is not in my database . ( I`m a little surprised because if your radio is from 1996 then it should be )
However , if you email restoredclassic@aol.com then they may be able to help as they have access to a much larger Philips Database.
Mention this forum and there should be no charge.
Username: Lunula
Hello Reg,
I need to your help for my car radio code.
thanks for your help.
Car: Peugeot 106(year 2000)
Serial number:VF31CKFXEYM002295
Post Number: 457
ayhan ulusoy
Username: Lunula
Posted on Wednesday, February 04, 2009 - 07:41 am:
Insufficient Informatoin...Please read the following
..................................IMPORTANT NOTICE ............
....................PLEASE READ BEFORE POSTING A REQUEST FOR A CODE ................
TO MAKE ANY ATTEMPT AT PROVIDING A FREE CODE FOR YOUR RADIO I REQUIRE THE FOLLOWING INFORMATION
1...MAKE and MODEL of the RADIO
2...ALL the NUMBERS and LETTERS on ANY LABELS , BARCODES or STAMPED IN THE METAL CASING OF THE RADIO
3...MAKE of CAR
I`m afraid supplying just the VIN number or MAKE of car or single Serial Number is sometimes not enough ..
I require ALL the above information .
If any of this information is missing then there is a good chance that your question will be ignored.
Sorry about this but it is time consuming to keep asking for this information in reply to any incomplete code requests
Username: Hgalindoxp
Mexico, Distrito Fed...
Mexico
Hi, Reg Rooster
Sorry, The code does not activate the radio.
You can verify this!!?
Thanks
Humberto Galindo
Mexico
Posted on Tuesday, February 03, 2009 - 10:34 am:
Hi Reg Rooster
All the best for the new year !
I have a Renault Megane, can you help me? I need a radio code.
Radio Information:
Model No. 22DC278 / 62H
T0M199
RN278F0032886
PROD. No.:FD0403280032886
820005763TM199
8200057683
Your code should be 1704
Post Number: 461
Humberto Galindo
Mexico Post Number: 3
Posted on Wednesday, February 04, 2009 - 01:26 pm: Hi, Reg Rooster
Sorry, The code does not activate the radio. You can verify this!!?
Thanks
1704 is definitely the correct code for your radio.
The problem could be
1....Not entering the code correctly
see
http://www.radio-code.co.uk/code-entry-guide-DC278/62B/P%20Renault.htm?KeepThis= true&TB_iframe=true&height=260&width=450
2...Radio is semi-locked because previous wrong codes have been entered
(Solution :Leave it SWITCHED ON UNDISTURBED for as long as it takes to reset
3....Your radio has been recoded to a completely different number
Username: Vladwild
Hi
I have a Renault Scenic, can you help me? I need a radio code.
Radio Information:
Model No. 22DC278 / 62R
TOS580
RN278F20006595
PROD. No.:FD0002160006595
8200150474TS580
8200150474
Post Number: 485
Vladislav Vilkelionok
Username: Vladwild
Posted on Monday, February 09, 2009 - 03:53 am:
Hi
Radio Information:
TOS580
RN278F20006595
8200150474TS580
8200150474
Your code should be 7455
Username: Jacobi
Aalborg
Danmark
Hi, i need some help to my radio.
Philips
modelno. 22DC710/64S
PROD. FD0896498058769
Serial. PHF001T8058568
Thanks a lot
Mexico
Reg Rooster excuse me, record the code does not work, I noticed that you sent the wrong bar code, the correct is: 8200057683TM199.
Aditional data:
T0M199
RN278F0032886
Humberto Galindo
Thanks
see
3....Your radio has been recoded to a completely different numberUpload}}
Post Number: 494
Tom Jacobi Nielsen
Username: Jacobi
Aalborg
Danmark
Posted on Tuesday, February 10, 2009 - 06:15 pm:
Philips
Sorry , this Serial Number is not in my PHILIPS database. If you email restoredclassic@aol.com then they may be able to help as they have a much larger PHILIPS database. (Mention this Ecoustics Forum and there should be no charge)
Username: Mikegomes
Hi, please help me too,
My car is a opel combo .
i m from portugal
all the details and some pics
grundig car 2002
gm020221439057
type-car2002
no-09115094
many many thanks if you can help me
miguel gomes
Post Number: 495
Humberto Galindo
Mexico Post Number: 4
Posted on Tuesday, February 10, 2009 - 06:58 pm:
========================================================Model No. 22DC278 / 62H
T0M199
RN278F0032886
Your code is still 1704 as it has been double checked ....calculated by both software and manually using pencil+ paper
If this code still does not work , then your radio must have been recoded to a completely different number,
It will have to be taken in to be electronically read / recoded.
Post Number: 496
miguel pereira gomes
Username: Mikegomes
Posted on Tuesday, February 10, 2009 - 07:37 pm:
i m from portugal
grundig car 2002
gm020221439057
type-car2002
no-09115094
Sorry , this code will not be abvailable for free from anywhere on the Internet as iit is not in the usual GRUNDIG database
Main Dealer or Decode Specialist only
Username: September
Hi Reg,
I have a Philips BMW Business RDS
22DC785/23F
Serial: PH7850T1149284
KW 37/96 INDEX: 01
1997 BMW 318i
The car is in the USA but is asking for a 4 digit European code. I was able to get a 5 digit code from the Dealer for it which is: 51664
I have tried holding down the "M" key to reset the region to USA but the display never switches from CODE _ _ _ _ to SN#.
Would you have a code for it please? Thanks in advance.
Username: Thedownloadsxxx
Hellp
I need code for renault cd player
Made In Malaysia
renault
8200843548
7 648 053 591 FD891
905 BP8053 8 0989076
8200843548T Y153 SECURITY
03 479
Username: Paulie1981
Dublin
Hey Reg Rooster,
Could you please help me get my radio working.
its a Panasonic RDP202N 40w x 4
Model No. CQ-RDP202N
Serial No. PA0027Y0302465
Stamped in the steel is FA05594B and FA031359E
The car is a 1998 Mazda 323F
Thank you
Post Number: 526
Peter September
Username: September
Posted on Monday, February 16, 2009 - 06:51 pm:
Hi Reg,
22DC785/23F
KW 37/96 INDEX: 01
1997 BMW 318i
Sorry , this Serial Number is not in my PHILIPS database. If you email restoredclassic@aol.com then they may be able to help as they have a much larger BMW / PHILIPS database. (Mention this Ecoustics Forum reference number ERR121 and there should be no charge)
Post Number: 527
Renault cd
Posted on Tuesday, February 17, 2009 - 09:21 am:
Hellp
Made In Malaysia
renault
8200843548
7 648 053 591 FD891
03 479
Your code should be 1885
Post Number: 528
paul smith
Dublin
Posted on Tuesday, February 17, 2009 - 09:50 am:
Hey Reg Rooster,
Sorry , I am unable to help with this code
Dublin
Thanks for trying anyway
Username: Kerry_s
hi i have just bought a renault scenic 2000 model with a tunerlist radio. code i was given dosent work though :-(
can you help please.
tuner list 22dc259/62p
7700434424 ta595
toa595
rn259f10282850
prod: fd0501250282850
thats all the numbers i could find on the unit.
Post Number: 536
kerry
Username: Kerry_s
Posted on Tuesday, February 17, 2009 - 03:27 pm:
7700434424 ta595
toa595
rn259f10282850
(Quote reference ERR2 and there should be no charge)
Username: Kennelking1
hello I have a
make :BLAUPUNKT
model:bmw business cd
serial:bp027340141083
can you help please
Post Number: 540
Roy C
Posted on Wednesday, February 18, 2009 - 08:07 pm:
hello I have a
make :BLAUPUNKT
Quote all the other letters+numbers on this radio especially any beginning with 7 *** *** ***
hello I have a
make :BLAUPUNKT
part#7640273342
Post Number: 542
Roy C
Posted on Thursday, February 19, 2009 - 03:01 pm:
hello I have a
make :BLAUPUNKT
part#7640273342
Your code should be 6658
Username: Lebowsky
In the same situation... Renault clio 1.5l DCI
MAKE: PHILIPS/RENAULT
MODEL: 22DC278/62B
M553
RN278F40814332
PROD NO: FD0804170814332
8200057681TM553
Tanks, it's pretty hard to drive without radio ;-)
Post Number: 555
tonton bens
Username: Lebowsky
Posted on Friday, February 20, 2009 - 05:05 pm:
MODEL: 22DC278/62B
M553
RN278F40814332
8200057681TM553
Your code should be 0964
Username: Mmf1
Dear Reg Rooster,
Can you help me out with the radio code for my car?
2006 Honda Accord EX (w/ navigation)
Radio S/N is 22002334. Thanks!
Username: Mmf1
BTW, it's an Alpine. Thanks.
Post Number: 558
Mr Mastodon Farm
Username: Mmf1
Posted on Friday, February 20, 2009 - 08:57 pm:
Sorry , I can not provide the code for this ALPINE radio.
Main dealer or Decode Specialist only.
Username: Moisnik
Tallinn
Estonia
2001 y passat
Radio S/N is oe: vwz1z3w7940981 .
Thanks!
Post Number: 582
andres
Username: Moisnik
Tallinn
Estonia
Posted on Wednesday, February 25, 2009 - 07:57 am:
2001 y passat
Thanks!
Your radio is made by BLAUPUNKT so if you can quote ...ALL the NUMBERS and LETTERS on ANY LABELS , BARCODES or STAMPED IN THE METAL CASING OF THE RADIO then I might be able to help.
There should be a number beginning with 7*** *** ***
Username: Moisnik
Tallinn
Estonia
Post Number: 584
andres
Username: Moisnik
Tallinn
Estonia
Posted on Wednesday, February 25, 2009 - 09:40 am:
7648227060
Try 2670 and if that does not work then I do not think that this code will be available for free from anywhere on the internet.
You will have to try your VW Main Dealer or a Decode Specialist
Username: Dazbro
Hi can you please help with the code for my car radio. Info as follows
renault scenic V reg 1999
phillips model no: 22dc481/62
prod no: fd 1299359249571
other details on radio
renault radiosat 6000
9022 214 81629
7700 433 070
regards
darren
Post Number: 587
darren brook
Username: Dazbro
Posted on Wednesday, February 25, 2009 - 05:41 pm:
9022 214 81629
7700 433 070
There should be a 14 character Serial Number plus a Security Number consisting of letters+ digits somewhere on your radio.
Possibly on a label or barcode or stamped in the metal casing
See the example here
Username: Dazbro
hi again.
I've found the serial number which is
RN481FX9249571
not sure about the security code; nothing obvious.
there are two other sequences:
M/CH:249737
7700433070Y861 (possibly Y861)
Regards
Darren
Post Number: 588
darren brook
Username: Dazbro
Posted on Thursday, February 26, 2009 - 02:39 pm:
hi again.
RN481FX9249571
M/CH:249737
Sorry..these numbers are not in my PHILIPS database
Username: Dazbro
hi reg booster thanks for the recommendation to use restoredclassic. hurrah i now have a radio which works
regards
darren
Username: Kerr1977
Radio code required please
phillips 22DC481/62
9022 214 81629
FD 1099089125009
SERIAL NO. 7700433070T973
Post Number: 590
ian kerr
Username: Kerr1977
Posted on Friday, February 27, 2009 - 06:52 am:
phillips 22DC481/62
9022 214 81629
FD 1099089125009
Duplicate request...Already answerted in the other thread
Username: Mustang65
Hamburg, Germany
Hope you can help me :-)
My Radio
Mercedes Benz MF2910
Q15
Serial-NO: 2910 Y 08 33966
Titel: A170 820 0386 0080
DESTR142282
Car-No.: WDB1680331J119588
Greetings Klaus
Username: Rob_lok
I really need some help with my 96 BMW car radio, says i need a code? Hope this helps.
Post Number: 595
Klaus Hirschfelder
Username: Mustang65
Hamburg, Germany
Posted on Friday, February 27, 2009 - 04:08 pm:
My Radio
Q15
DESTR142282
Duplicate request.....Already answered in other thread.
There is no need to post any request more than once !
Post Number: 596
Robert
Username: Rob_lok
Posted on Friday, February 27, 2009 - 06:16 pm:
This is a BMW / ALPINE radio and difficult to decode.
Try 21163 ....and if this does not work then I don`t think your code will be available for free from anywhere on the Internet.
Main Dealer or Radio Decode Specialist only
Username: Rob_lok
I think its a four digit code but i'll try it anyway, in anycase thanks for your help.
-Rob
Post Number: 598
Robert
Username: Rob_lok
Posted on Friday, February 27, 2009 - 08:22 pm:
-Rob
According to my database the BMW C33 Alpine requires a five digit code.
Username: Turboclaw
Hope you can help
2000 Audi A4
Symphony
Model - 8D0 035 195 A
SERIAL NO. 113277
Manufactured January 2000
AUZ5Z4Y009508 1
Please let me know if you need anything else.
James
Username: Meli_nda84
Hi, I need your help.I have a peugeot 206 with a BLAUPUNKT radio cassete.
STAMP: BP8145W8820743
7648145392
on one side.
T1 TOP : 96 251 334 80
code bar: C6BPN8820743
C72000001053
Username: Manny_bori
Hi:
I need the radio code for a:
1998 ACURA 3.0CL
Radio Bosse
Model # - 39100-A010
Ref # - CQ-JH07142
Serial # - M97E108292
Label # - M2C414033
Username: Looping
Hi,
I need a code for a BECKER AVUS serial BE2035T6011688 . thanks!
Post Number: 604
Daraban Melinda
Posted on Saturday, February 28, 2009 - 10:07 pm:
7648145392
on one side.
C72000001053
Your code should be 1435
Post Number: 605
loopinglooping
Username: Looping
Posted on Sunday, March 01, 2009 - 05:34 am:
Hi,
Your BECKER requires a four digit code.
Try 8387
Post Number: 606
Manuel Pagan
Posted on Sunday, March 01, 2009 - 04:02 am:
Hi:
1998 ACURA 3.0CL
Radio Bosse
Ref # - CQ-JH07142
Label # - M2C414033
This radio is made by MATSUSHITA and requires a five digit code.
Try 35412 or 11414
If neither work then this code will not be available for free on the Internet.
Main Dealer or Decode Specialist only.
Username: Turboclaw
Sorry for the repost, Hope you can help
2000 Audi A4
Symphony
SERIAL NO. 113277
AUZ5Z4Y009508 1
James
Post Number: 609
James
Username: Turboclaw
Posted on Sunday, March 01, 2009 - 11:06 am:
2000 Audi A4
Symphony
SERIAL NO. 113277
AUZ5Z4Y009508 1
This is a MATSUSHITA radio requiring a four digit code between 0000 - 1999
Unfortunately it is not available for free from anywhere on the Internet.
(or your local Car Radio / Audio Shop if you have one as they are usually the cheapest option)
Username: Looping
THANK YOU REG ROOSTER!!! The code you gave me works perfectly!!!!(becker avus) thanks a lot ! bye!
Username: Rob_lok
Your right it is a five digit code but 21163 did not work, so main dealer it is i guess, but will they charge me just for the code? if so, how much would you estimate it would cost me?
Post Number: 616
Robert
Username: Rob_lok
Posted on Sunday, March 01, 2009 - 07:11 pm:
The only way to find out is to ring up and ask as it depends whereabouts in the world you live.
Here in the UK the cheapest option would be to take it to a local Car Radio / Audio shop who might charge £10 / £20 by reading the memory chip (EEPROM)
The Main Dealer should have access to the original factory database ....and will charge as much as they like for the code.
Anything from free up to £100 plus !
Username: Ange1969
Hi
Please can you help with my unlock code:
Phillips 22DC279/622
TO0154
RN279F20292746
Prod No FD0202220292746
Renault Laguna Authentique 02
Hope you can help
Ange
Post Number: 643
Angela Smurthwaite
Username: Ange1969
Posted on Saturday, March 07, 2009 - 04:43 am:
Hi
TO0154
RN279F20292746
Sorry ....not in my PHILIPS database
Username: Ange1969
Ok thanks for looking Reg.
Username: Kevgriggs
Hi Reg,
Could do with a code myself.
Details are:
Rover CD43 (Blaupunkt)
Serial No - BP026328499651
Part No - 7 640 263 342/40/44/46
Bar Code - 2 8499651
Also stamped in the case:
8 631 312 925
And a couple of other numbers on a label on the top:
XQE 100 380
FD242 Index 51
Look forward to hearing from you!
Thanks, Kev.
Post Number: 645
Kev Griggs
Username: Kevgriggs
Posted on Saturday, March 07, 2009 - 08:22 am:
Hi Reg,
Details are:
8 631 312 925
XQE 100 380
FD242 Index 51
Try code 8617
Username: Maverickrulls
Hi guys, please help me with the code for my radio CD:
RN277F20006462
FD0002350006462
T0F341
Thank you and have a nice evening!
Post Number: 658
Ioan Agarbiceanu
Posted on Monday, March 09, 2009 - 01:28 pm:
RN277F20006462
FD0002350006462
T0F341
Sorry...not in my PHILIPS database
Post Number: 660
Kev Griggs
Username: Kevgriggs
Hi Reg,
Details are:
8 631 312 925
XQE 100 380
FD242 Index 51
Try code 8617
Username: Nikolair
Philips 22DC459/62L
Prod No FD 0798114087777
9022 214 59624
7700 426 412 V537
many thanks
Post Number: 681
nik
Username: Nikolair
Posted on Wednesday, March 11, 2009 - 06:51 pm:
Philips 22DC459/62L
9022 214 59624
7700 426 412 V537
Why have you asked the SAME question in THREE different threads?
If you are that impatient , then you had better go straight to your Main Dealer or a Decode Specialist
Username: Nikolair
Sorry...
Username: System1981
Semipalatinsk, VKO
Kazakstan
Hi
Model:AUDI GAMMA CC (GRUNDIG)
Serial No:AUZ2Z3R1107342
Car: AUDI A6
Thank you!
Post Number: 685
Kirill
Semipalatinsk, VKO
Kazakstan
Posted on Thursday, March 12, 2009 - 06:59 am:
Hi
Car: AUDI A6
Thank you!
Your code is 0803
Post Number: 687
nik
Username: Nikolair
Philips 22DC459/62L
9022 214 59624
7700 426 412 V537
Your code is 4446
Username: Susieq1957
Need radio code for 02 BMW Z3 - Radio Serial Number is 29965492
Post Number: 694
Susie Moran
Posted on Thursday, March 12, 2009 - 02:08 pm:
BMW do not make radios .They only affix their badge onto radios made by the large manufacturers (ALPINE , BLAUPUNKT etc).
In order to attempt to calculate your code , please supply your radio MAKE+MODEL plus ALL the NUMBERS+LETTERS on ANY LABELS , BARCODES or STAMPED IN THE METAL CASING
Username: Bubblez36
i need the radio code for a mercedes benz 190 E
Post Number: 695
krystyna
Username: Bubblez36
Posted on Thursday, March 12, 2009 - 10:47 pm:
Insufficient Information...Please read the following
3...MAKE of CAR
I require ALL the above information . {/b
Username: Spektral
Hi there,
Please could you help me with unlocking my Rover 214 Radio/Cassette head unit?
The Details are as follows:
Make: Philips
TYPE NO: 22 DC 349/60B
RG PART NO: XQD101020
DIGITAL COMBI: 3BAND
PRODUCT NO: FD0596431043396
Engraved Serial on side: RG349FT1043396
I would be very grateful for any help you could provide.
Regards, Matt
Post Number: 714
Matt Cox
Username: Spektral
Posted on Sunday, March 15, 2009 - 12:17 pm:
Hi there,
Make: Philips
Username: Gamerpr0
Hi there,
Please could you help me with unlocking my radio code for 1994 bmw 540I.
MAKE and MODEL of the RADIO : Dolby System (can't find a model #)
Engraved Serial number:F21013572A
Make and Model of Car: 1994 BMW 540i
Car Id:WBAHE6316RGF27055
Much thanks -Michael}
Username: Diybilko
Manchester, England
Hi,
Can you please help me?
I need the 4 digit code for my radio in my clio 1.4 dynamique on a 51 plate.
I changed the battery and now it wont work.
These are all the details from the radio itself:
Model No: 22DC278/62B
TOX833
RN278F10013046
PROD No: FD0101190013046
820005768ITX833
8200 057 681 --A
Thats all i can see on the radio,Its just a standard radio, but you dont realise what you had untill it gone, and would like it back please...
Please help me fix it.
Kindest regards.
Diybilko
Username: Ewolf
HAllo,can you help me! ,please,I need kode for my car radio sony cdx-m8800 serial no. 3587334, Thank you!
Username: Decode
Post Number: 26
Darren Fisher ------> code 2179
If this code has helped you in anyway - and you want to say thanks...
this is my paypal e mail:
lynx222@o2.pl
Post Number: 741
arturas
Username: Ewolf
Posted on Thursday, March 19, 2009 - 09:30 am:
SONY codes are not available for free from anywhere on the Internet
Main Dealer or DEcode Specialist only
Username: Renaultclio
Hallo please help me need reg radio code
Renaut:Clio
Model no. 22DC278/62B
TW623
RN278F30629817
Prod No: FD0503420629817
Then written under a barcode is;
8200057681TW623
Username: Decode
Post Number: 30
Povilas ------> code 3334
lynx222@o2.pl
Username: Tace
Hey could i get a code for my renault scenic(2005):
MAKE: RENAULT
MODEL: RENRDW131-10
Q588
SERIAL: RNRD0350255825
PROD NO: FD0705010255825
Thanks
Username: Drupi
hi,
I also need the code for my radio. My car is a renault scenic II.
the numbers are:
model: RENRDW 131-10
PROD. NO: FD0003200010852
RNRD0030010852
TOY029
8200300858TY029
THANK YOU
Username: Decode
Post Number: 37
cornel------> code 1938
If this code has helped you in anyway - and you want to say thanks ,like beer donation:-)...
this is my paypal ( www.paypal.com ) e mail:
lynx222@o2.pl
Username: Decode
Post Number: 38
tace87 ------> code 9417
lynx222@o2.pl
Username: Tace
Sorry, but its not working.. :-(
But Thanks!
Username: Decode
Post Number: 45
tace87--->If this is correct: Q588 code is correct too,or you are not entering the code correctly or radio has been recoded
Post Number: 764
tace87
Username: Tace
Posted on Tuesday, March 24, 2009 - 09:52 am:
But Thanks
Try code 1413
If this does not work check all your numbers again and make sure you are entering the code correctly
Username: Bosse
Hi
I bought my car yesterday but need the code for my radio. On the label I found:
Model no: 22DC279/62T
TOA859
RN279F20234294
Prod no: FD0402370234294
The car is a Renault Megane
Anyone who can help me with the code ?
Post Number: 776
B Roos
Username: Bosse
Posted on Friday, March 27, 2009 - 08:11 am:
Hi
TOA859
RN279F20234294
Your code is 0396
Username: Bosse
Thanks - now we got music in the car
Username: 0120
United Kingdom
please can anybody help me with the radio code for Mitsubishi Montero Sport 2001.
Radio model MR472957
S/N 13084116F
Post Number: 782
mark
Username: 0120
United Kingdom
Posted on Saturday, March 28, 2009 - 08:28 am:
S/N 13084116F
This radio is made by MATSUSHITA and requires a four digit code.
Unfortunately these codes are not available for free from anywhere on the Internet.
Main Dealer or Decoding Service or your local Car Radio / Audio Shop (who will normally be the cheapest option)
Home > Message Board > Car Audio > Security Systems > Radio Codes For Free > Archive through March 28, 2009 [ « Previous ] [ Next » ]
