Thread: 6x9 to 6.5? |
Bronze Member Username: Wfbass
Stephenville,
NL
Post Number: 94 Registered: Sep-08
| Posted on Friday, May 29, 2009 - 12:53 pm: |
im about to take out my stock 6x9 and put in 6.5 diamond audio D6 components and take out my 4x6 and put in 5.25 D6 components. was this a good idea or wha? i know that it will be better then stock for sure just wondering how diferent the 6x9 to 6.5 change will be |
Platinum Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 10498 Registered: Jul-06
| Posted on Friday, May 29, 2009 - 01:17 pm: |
Of couse it will be better... comp speakers vs stock, duh. And you won't fit 5.25s in a 4x6 unless your cutting stuff. And why are there two different sets of components here..... lose the rears |
Stephenville,
NL
Post Number: 96 Registered: Sep-08
| Posted on Friday, May 29, 2009 - 05:21 pm: |
" i know that it will be better then stock for sure " yeah no duh thats what i said. they'll fit one way or the other but i know how to make them fit without cutting. thanks for the suggestion but im gonna keep my rears . can anyone else anwser my question? "how diferent the 6x9 to 6.5 change will be" |
