Home > Message Board > Car Audio > Head Units > No Rca Cables
Author Thread: No Rca Cables
Username: Jerel_coles
Pennsylvania
United states
Post Number: 9
if ur head unit has no rca cables .. will ur system sound better with them cuz i had a mb quartz 1500.1 running on a head unit without them .. cuz my sony explode didnt have rca cables so my amp blew so i bought a new head unit with sw output and im waiting to get my amp back will it sound better
Username: Robvan69
Alberta
Post Number: 11
you need rca cables to hook up an amp in my opinion, some people install a converter on the speaker leads to make rca connections but that power to your amp is controlled by the volume on your deck plus you lose speaker power as well. I would get a deck with rca sub outputs, that would sound best in my opinion, then you can control the sub seperately from the rest of your speakers.
Username: Subfanatic
Ky
Post Number: 4843
yes just get a line output converter. to hook it up it just takes a little splicing into your current speaker wires near the head unit. Then RCA cables plug right up. About 30 bucks at a car audio shop/bestbuy or something
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Head Units > No Rca Cables [ « Previous ] [ Next » ]
