Home > Message Board > Car Audio > Security Systems > Ford 6000cd cd player code
Author Thread: Ford 6000cd cd player code
Username: Badboyben
hi i lost my code for my cd player help in finding this would be brill,
serial no is m111803
part no. ys4f-18c815-ad
Username: Regrooster
Post Number: 1038
Your code is 9391
Username: Maisa188
hi
i also lost my ford 6000 cd code, please help me to get it serial no M076063
Username: Decode
POLAND
Post Number: 177
soso------> code 9489
If this code has helped you in anyway - and you want to say thanks ,like beer donation:-)...
this is my paypal ( www.paypal.com ) e mail:
lynx222@o2.pl
Username: S0rinell
Craiova, Dolj
Romania
Hi, i lost my FORD 6000 CD code.. please help me to get it!!
the serial no is M070200
thanks
Post Number: 1312
s sorin
Username: S0rinell
Craiova, Dolj
Romania
Registered: Jun-09 Posted on Thursday, June 25, 2009 - 01:18 pm:
Your code is 7728
Username: S0rinell
Craiova, Dolj
Romania
thank you, i'll try it tomorow morning.. i hope it is working :D
thanks again
Username: Uniq
the serial no is M235991
Post Number: 1393
ca
Username: Uniq
Registered: Jul-09 Posted on Monday, July 06, 2009 - 01:02 pm:
Try 0676
Username: Luchian
the serial no G079383
thanks
Post Number: 1409
Condrea ionel lucian
Username: Luchian
Registered: Jul-09 Posted on Saturday, July 11, 2009 - 09:05 am:
Check your Serial Number again.
Ford Serial Numbers normally start with letter M , V , L or C
Username: Dj4t67
HELLO !
i'haven't my code for my new car, it's a Ford Focus a 1999 years can you help me please?
my references:
radio 5000 RDS EON
serial : M344847
Thanks !!!!!!
Marc
Post Number: 1410
Marc Meyer
Username: Dj4t67
Registered: Jul-09 Posted on Sunday, July 12, 2009 - 11:33 am:
HELLO !
my references:
radio 5000 RDS EON
serial : M344847
Thanks !!!!!!
Marc
Try code 6295
Username: Thrashingmaniac
Need the code for my 6000 CD player too, the one I was given with it doesn't work, serial number is M198310
Post Number: 1487
Adam Harding
Registered: Jul-09 Posted on Wednesday, July 22, 2009 - 01:58 pm:
Try code 5932
Username: Lucki
Hiya RR, can you do v codes?}
Post Number: 1570
No...V Serial Number codes can only be obtained from the FORD Main Delaler or a Decoding Service
Username: Fistach
Could you Help me? please
Model: 6000NE
Serial No: M085545
Part No: 1L2F-18c838-CD
Post Number: 1678
karol
Username: Fistach
Registered: Aug-09 Posted on Saturday, August 22, 2009 - 05:59 am:
Model: 6000NE
Serial No: M085545
Your code is 4789
Username: John_woodards
Hello, could you help me locate the code for this model please.
model: 6000cd rds e.o.n
serial number: M025752
Thank You.
Post Number: 1743
ohn woodards
Registered: Aug-09 Posted on Friday, August 28, 2009 - 08:46 pm:
Try code 4237
Username: L1f3
Hello, I lost my code for YS4F-18C815-AD, model : 6000cd rds e.o.n , serial: M418414\
Thanks a lot :-)
Post Number: 1788
Tomas
Username: L1f3
Registered: Sep-09 Posted on Saturday, September 05, 2009 - 10:56 am:
try code 5124
Username: Mcq
Hi new to this forum and hoping you can help. I have a ford focus c-max 2004 with 6000cd. Changed alt and battery and now need key code as I didn't buy the car new and no code left in my book. Model no. is M215803. Kind regards to everyone.
Username: Amilo
Post Number: 14
Douglas Alexander
Username: Mcq
your ford code is 5196
Username: Mcq
David Amilo, thanks very much, some excitement in our house tonight!
Username: Okcomputer44
I had to change the battery in my car and the code does not work for my RDS 6000 CD radio.
Any advice would be much apreciate please.
The serial number is: M260173 and Part No is: YS4F - 18C815 - AA.
Thank you for your help.
Laz.
Post Number: 1971
Laszlo Szabo
Registered: Oct-09 Posted on Sunday, October 04, 2009 - 06:23 pm:
Try code 6793
Username: Rags0408
Arlesey, Bedfordshire
GB
HELP!!! I have recently changed my battery and my manufacturers code (5958) for my radio (Ford 6000CD) does not work.
My is serial no: M063980, my unit type is FD 6000
I would really appreciate if you can help out on this.
Cheers
Roger
Post Number: 2054
Roger Payne
Username: Rags0408
GB
Registered: Oct-09 Posted on Thursday, October 15, 2009 - 04:50 pm:
Cheers
Try code 5958
Username: Sjaakie12
Hey where can i find the serialnr. and part. no?
on my 6000 cd rds eon
Post Number: 2104
sjaak
Username: Sjaakie12
Registered: Oct-09 Posted on Wednesday, October 21, 2009 - 09:25 am:
Remove the radio from the dashboard and there should be a label with a Serial Number beginning with M++++++ (or L or C or V )
Here is a video showing how to remove your radio from the dashboard. A pair of extractors are required (available from Ebay , Halfords ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
http://www.fitaudio.com/videos/din_keys_guide/video_din_size.html
Username: Sjaakie12
Hey
Thanks for your response but the video isn't working. :-(
Post Number: 2105
It looks as though the website has been redesigned
Try YouTube
http://www.youtube.com/watch?v=iSbzR9lv2OM
Username: Tautvisz
hello whats the code cd 6000 M 147308 thanks
Post Number: 2133
tautvydas
Username: Tautvisz
Registered: Oct-09 Posted on Sunday, October 25, 2009 - 03:18 pm:
try code 7299
Username: Yinglai
Can you get a Code without taking the whole CD player out?
Post Number: 2171
No
http://www.youtube.com/watch?v=urC-4NbXvDQ
Username: Yinglai
Where abouts would it be located on the back of the CD player?
many thanks.
Post Number: 2177
Usually on a label on the metal casing
see
http://carradiohelppage.comlu.com/wpimages/wp498aebd5.png
Username: Safc
Hi does any one have the code for ford stereo 6000 rds, serial number M279155.
Thanks
Post Number: 2182
Will
Username: Safc
Registered: Nov-09 Posted on Sunday, November 01, 2009 - 08:01 am:
Try code 6742
Username: Alen00
Hi. i lost my code for my player Ford 6000CD VPP059393! Can you help me?
Post Number: 2236
Alen
Username: Alen00
Registered: Nov-09 Posted on Monday, November 09, 2009 - 06:29 am:
Please checheck your Serial Number again as Ford Serial Numbers are a LETTER followed by SIX DIGITS
eg..M123456 or V123456 etc.
Please note ..If it begins with V++++++ then it cannot be decoded for free.
Main Ford Dealer or a Decoding Service only for these
Username: Lolib
After entering code three times, it started asking us for code2 ... Do you know where to get code2? It's model 6000CD... Thank you.
Post Number: 2287
Loli Bayer
Username: Lolib
Registered: Nov-09 Posted on Friday, November 20, 2009 - 04:31 am:
You must be using the wrong code
Remove the unit from the dashboard then post the SERIAL NUMBERS found on the label on the metal casing
Username: Jamesy1
Mid glam
United Kingdom
Hi all could someone please help when buying a new van this week the battery was changed the previous owner has misplaced the service book with the code in it. SERIAL NO: M024931 Thanks
Post Number: 2293
MARK JAMES
Username: Jamesy1
Mid glam
United Kingdom
Registered: Nov-09 Posted on Saturday, November 21, 2009 - 03:34 am:
Duplicate Post....Already answered
PLEASE DO NOT POST THE SAME REQUEST IN TWO DIFFERENT THREADS !
Username: Pac2003
hi, could someone please help with my 6000 cd player. changed my battery and now need to enter code. serial number: M003348
Many thanks
Post Number: 2323
lloyd parkes
Username: Pac2003
Registered: Nov-09 Posted on Monday, November 23, 2009 - 10:49 am:
Many thanks
Try code 0821
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Security Systems > Ford 6000cd cd player code [ « Previous ] [ Next » ]
