Home > Message Board > Car Audio > EQs and Crossovers > PS2 to 12 V
Author Thread: PS2 to 12 V
Username: Martez91
Im trying to put my PS2 into my head unit (double din alpine), i am not too sure how to plug up the PS2 into my car and im a bit cheap and dont want to spend too much, im happy to open up my ps2 and fiddle with it but im not too sure exactly what to do to convert it to 12V, can someone please tell me what i need to take out of the PS2 / wires to cut / what to put in.
its not the slim line one
cheers.
Username: Tedsprogz
Nunya, Florida
US
Post Number: 63
get a power inverter then plug the AC cord into it then plug the RCA's into the head unit. viola.
Username: Creator1
I have the Slim PS2 in my Show truk- fits in the glove compartment, I found a 12v cord from the Vid gaming store, either plug it into the cigarette lighter, OR cut the plug off and hardwire to a 12v source. IF u cant find the dc adaptor cable, then yes- u can use an invertor 12>110v, just more expense. The SLIM one takes 8.5 volts at like 6 amps- so instead of trying just any DC cable, I found the ONE for it at that vid game store less than $20 bucks. Must be one near you :-) U'll still need ur deck or head unit to have L&R & Vid INPUTs. IF ur deck doesnt, Audio Control 4.1i, has an AUX input so u can get the stereo signal into ur system (its a pre-amp/Para bass dash eq)- BUT- then u'll still need an INPUT for the video (assuming ur deck doesnt have a vid screen?) :-)
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > EQs and Crossovers > PS2 to 12 V [ « Previous ] [ Next » ]
