Thread: $300 head unit |
jimbojohn Unregistered guest |
| Posted on Friday, June 18, 2004 - 11:55 am: |
im going to put together a system over time because i dont have enough money for everything right now, but i want to start with a decent head unit. im looking to spend around $300. what do you recomend. |
Pioneer Unregistered guest |
| Posted on Friday, June 18, 2004 - 11:58 am: |
Pioneer P960 MP |
Bronze Member Username: Suppabob
Post Number: 14 Registered: May-04
| Posted on Friday, June 18, 2004 - 01:57 pm: |
eclipse cd3403 Or any eclipse deck you can afford. |
| Posted on Monday, June 21, 2004 - 04:05 pm: |
i like the pioneer but it is really expensive, are their any other nice pioneers that arent as pricy |
| Posted on Monday, June 21, 2004 - 04:14 pm: |
how is the P7500MP |
Pionner Unregistered guest |
| Posted on Tuesday, June 22, 2004 - 05:17 am: |
I have the P7600MP. Itīs a really nice and not too expensive. Organic display, lotīs of EQ funtions, ASL, great FM tuner, tons of features...Comparing with the 7500MP the difference is that the P7600MP is the newer version with a couple of newer features, mainly faster access times on MP3. And when I say faster, I mean realy fast, just as fast as switching between normal audio CD tracks. The only drawback on the newer P7600MP is that you canīt upload new sceensavers as with the P7500MP. In either choice, if you are looking to add ampīs, go with the Pioneer Premier line cuz they have higher voltage pre-outs (hence cleaner signal). But altogether, there are plenty of Pioneer head units you can find with probably the best Price Quality factor out there. Best value for the buck. I dare anybody to name any other that compares. jimbojohn, whatever your choice, good luck! |
| Posted on Tuesday, June 22, 2004 - 10:01 am: |
thanks a lot for your help |
Bronze Member Username: Salstang00
Boynton Beach,
FL
Post Number: 18 Registered: Jun-04
| Posted on Tuesday, June 22, 2004 - 10:28 am: |
http://search.ebay.com/P7600MP_Car-Audio-In-Dash-Units_W0QQsofocusZbsQQsbrftogZ1 QQfromZR10QQcatrefZC6QQsacategoryZ48602Q26catrefQ3DC6QQsosortpropertyZ2QQsosorto rderZ2 Great prices on the Pioneer.... |
