Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Autopage remote start/ alarm system help
Author Thread: Autopage remote start/ alarm system help
tsiturbo
i bought a car with the autopage system in it and the lcd screen. it was working fine, and then when i did some engine work it started acting up. when i put the battery in the keychain it either blinks (showing the whole screen) or whenever i hit a butto it just shows all the icons and does nothing. is there a switch i maybe hit or something? thanks for the room
neonb
http://www.autopageusa.com/
got to this website and contact autopage and maybe they can help you.
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Autopage remote start/ alarm system help [ « Previous ] [ Next » ]
