Thread: Installing/wiring a head unit |
regal man Unregistered guest |
| Posted on Thursday, June 17, 2004 - 12:10 am: |
i'm putting a sony explode into my '94 regal...if anyone has any information about this HU or car stereo system...it would be much appreciated...particularly connecting the antenna wires for the radio hook up to the head unit |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 143 Registered: Jun-04
| Posted on Thursday, June 17, 2004 - 12:28 am: |
Well its all pretty much color coded. You will have two hanresses. One to plug into the stock harness of the car and the other for the headunit. The either solder or crimp all the wires together by matching up color plug and play and you finished pretty much. |
| Posted on Thursday, June 17, 2004 - 03:19 pm: |
thx...lil more tho...there are two blue wires for on the stock harness and one on the HU harness labeled for the remote (which i don't have)...any ideas on what those two might be? P.S. there are 2 extra orange wires on the HU named illumination (no orange wires on stock harness) |
| Posted on Thursday, June 17, 2004 - 09:51 pm: |
I don't know about the two blue wires from the stock, but the blue from the HU is to signal an amplifier to turn on or off when you turn your HU on or off. I suggest going to Bestbuy or Circuitcity for a harness. I've seen the at Walmart too. About 5-10 bucks, all problems solved. Good luck |
| Posted on Sunday, July 18, 2004 - 04:32 pm: |
Yo what up? ya, i tried installing a head unit in my dad's car, a 1986 chevy celebrity, and well lets just say i messed some of the things on the dash up. I got the dash back together, but i cant seem to get it apart enough, when i had it apart, to take out the stock system and install my new head unit and then reinstall the dash. If anyone has any advise please help! thankx!!! |
| Posted on Saturday, July 31, 2004 - 12:48 am: |
i need the color codes for the stereo on a 2000 mitsubishi mirage. i can't find it anywhere. |
NorthWest,
Michigan
Post Number: 4334 Registered: Dec-03
| Posted on Saturday, July 31, 2004 - 01:18 pm: |
on a sony the two blue wires are for power antenna, and remote trigger for amplifiers 1993-94 Buick Regal Stereo Information Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 4" Dash Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
shaunoss Unregistered guest |
| Posted on Saturday, September 04, 2004 - 04:38 am: |
me mum has a 98 honda crv and i am trying to install an alpine deck model (CDM-7823E) that my bro was given by a mate who upgraded and i have no idea which wire goes to which because all wires from the car go into a large plug and there are then small holes to insert wires. a little help would be appreaciated |
| Posted on Tuesday, October 12, 2004 - 01:10 pm: |
Hi, I have a 1987 chevy celebrity. for the life of me I cannot get the stock stereo out. well let me say that I can't get the dash off. i took all the screws I could find out but it just won't move. Can someone please help me. Thanks! |
| Posted on Monday, October 18, 2004 - 10:32 am: |
hi i want to wire up my sub to my cd player but i cant get the cd player out to do so. i have a peugeot 106 with a clarion DRB3376E cd player can you help please |
VampiricLord Unregistered guest |
| Posted on Sunday, October 24, 2004 - 02:17 pm: |
Just one question, where does the ground wire goes? I have a 1992 Toyota Paseo. Also, should I cut the wires already there to crimp them with the ones for the head unit?? |
| Posted on Wednesday, October 27, 2004 - 02:49 am: |
Does anyone know how to bypass the parking prake lock on the newer sony's? Where do I connect the illumination? |
