Thread: Search code BLAUPUNKT WERKE |
New member Username: Abdel89
Post Number: 5 Registered: Mar-09
| Posted on Friday, April 17, 2009 - 04:10 pm: |
Hello I replace the battery in my Twingo. Light in my car I asked to enter a code. Someone to help me, I es more code. Radio BLAUPUNKT WERKE GMBH 7648126391 BP8126Y4967854 thank you help is welcome |
Silver Member Username: Regrooster
Post Number: 867 Registered: Aug-08
| Posted on Friday, April 17, 2009 - 04:23 pm: |
Your code should be 7935 |
New member Username: Falkmx
Post Number: 1 Registered: Apr-09
| Posted on Thursday, April 23, 2009 - 07:40 am: |
Hello I replace the battery in my VW: Blaupunkt 7 612 001 377 BNO 881 VWZ1Z2C3507631 1J0035191A thank you help is welcome |
New member Username: Tanvir
| Posted on Thursday, April 23, 2009 - 09:24 am: |
1994 Ford Fairmont Sedan VIN number 6FPAAAJGSWRB44133 ENGINE NO JGSWRB44133 I require a security code for the Radio. Any feedback will highly be regarded |
Post Number: 911 Registered: Aug-08
| Posted on Thursday, April 23, 2009 - 03:32 pm: |
Alfred New member Username: Falkmx Post Number: 1 Registered: Apr-09 Posted on Thursday, April 23, 2009 - 07:40 am: -------------------------------------------------------------------------------- Hello I replace the battery in my VW: Blaupunkt 7 612 001 377 BNO 881 VWZ1Z2C3507631 1J0035191A ============================================== VW BLAUPUNKT codes are very difficult to calculate. Try code 8994 or 0994 and if neither work then I don`t think it will be available for free from anywhere on the Internet. Main Dealer or a Decoding Service only |
Post Number: 912 Registered: Aug-08
| Posted on Thursday, April 23, 2009 - 03:40 pm: |
Tanvir New member Username: Tanvir Post Number: 1 Registered: Apr-09 Posted on Thursday, April 23, 2009 - 09:24 am: -------------------------------------------------------------------------------- 1994 Ford Fairmont Sedan VIN number 6FPAAAJGSWRB44133 ENGINE NO JGSWRB44133 I require a security code for the Radio. Any feedback will highly be regarded ============================================================= In order to attempt to calculate your code ,I require the RADIO details so please supply your radio MAKE+MODEL plus ALL the NUMBERS+LETTERS on ANY LABELS , BARCODES or STAMPED IN THE METAL CASING The VIN and Engine numbers are only used by the Main Ford Dealer who will (should? ) have access to the original Ford Manufacturer`s database. |
New member Username: Takalaka
Post Number: 1 Registered: Jul-09
| Posted on Friday, July 03, 2009 - 02:43 am: |
Hello I replace the battery in my Punto: Blaupunkt - WERKE , Fiat Punto 7 649 372 316 e1 021426 BP9372213848641 thank you help is welcome |
Gold Member Username: Regrooster
Post Number: 1363 Registered: Aug-08
| Posted on Friday, July 03, 2009 - 05:29 am: |
SB TAKALAKA New member Username: Takalaka Post Number: 1 Registered: Jul-09 Posted on Friday, July 03, 2009 - 02:43 am: Hello I replace the battery in my Punto: Blaupunkt - WERKE , Fiat Punto 7 649 372 316 e1 021426 BP9372213848641 thank you help is welcome ===================================== Try code 1442 |
New member Username: Themurry
Post Number: 1 Registered: Sep-09
| Posted on Tuesday, September 15, 2009 - 10:32 am: |
Hi, i have this : BLAUPUNKT-WERKE GMBH 7 644 840 060 VWZ1Z1S2901627 1HO 035 156 A I need the cod please help, thank you! |
Post Number: 1846 Registered: Aug-08
| Posted on Tuesday, September 15, 2009 - 05:20 pm: |
Zaharie Marian,Emilian New member Username: Themurry Post Number: 1 Registered: Sep-09 Posted on Tuesday, September 15, 2009 - 10:32 am: Hi, i have this : BLAUPUNKT-WERKE GMBH 7 644 840 060 VWZ1Z1S2901627 1HO 035 156 A I need the code =================================== This VW code is only available from the VW Main Dealer....or a Decoding Service |
New member Username: Angel51
Post Number: 2 Registered: Nov-09
| Posted on Wednesday, November 25, 2009 - 12:46 pm: |
Hello. I have a Skoda Radio Navigation made by Blaupunkt and I lost the book that contained the code. I didn't manage to obtian it using the regular Blaupunkt codes programs that are on the web. I would really apreciate your help. SKZ1Z7E 5045278 7 612 002 030 BNO 881 1UO 035 191B The above are the relevant codes, I think. Just to be sure I will post 2 other codes from the label 2139948 8618842980 Thanks a lot. |
Post Number: 2341 Registered: Aug-08
| Posted on Wednesday, November 25, 2009 - 07:04 pm: |
dy angel New member Username: Angel51 Post Number: 2 Registered: Nov-09 Posted on Wednesday, November 25, 2009 - 12:46 pm: Hello. I have a Skoda Radio Navigation made by Blaupunkt and I lost the book that contained the code. I didn't manage to obtian it using the regular Blaupunkt codes programs that are on the web. I would really apreciate your help. SKZ1Z7E 5045278 7 612 002 030 BNO 881 1UO 035 191B The above are the relevant codes, I think. Just to be sure I will post 2 other codes from the label 2139948 8618842980 ================================== Unfortunately this code will only be only available from your Main Skoda Dealer or a Decoding Service |
