Home > Message Board > Car Audio > Accessories > Archive through September 24, 2004 > TOo MUch Rattling
Author Thread: TOo MUch Rattling
Username: Gbstylez87
Post Number: 10
I have 2 12's rockford fosgate and a fosgate 200 watt amp pushing it. I hear some of the bass inside the car with everything vibrating. On the outside of the car the whole trunk, bumper, sides and everything rattles like crazy. You dont hear no bass just the rattling from the outside.
What do you guys reccomend for this problem?
Username: Illfaded
Post Number: 54
put sound deadening
Username: Rswan
Post Number: 108
if your seats can go down in the back put them down it will help alot. if not you can do what phycoticS said, or you can make a port on your rear deck
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 46
Get a custom box built and fire the subs foward not backwards. The reason I say custom box, is they can take the out side edges out about 2 inches from the face board, that the subs are mounted to. You can then go in and scribe the box to fit tight against the back of the seat, or the opening if your seat will fold down. I promise you will have better sound quality, less rattles, and louder base.
Home > Message Board > Car Audio > Accessories > Archive through September 24, 2004 > TOo MUch Rattling [ « Previous ] [ Next » ]
