Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Tundra 2000 security
Author Thread: Tundra 2000 security
Username: Gmluckie
Montgomery, AL
United States
alarm system activates when tailgate is lowered or bumped. locking and unlocking doors does not deactivate the alarm system. Locked out starter truck will not start. Anyone know how to deactivate the alarm and start the engine
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 75
sounds like the brain is about fried. I would try to put it in valet mode. If it is a clifford you can do it via the remote, or the coded valet switch. If it is another brand the manual should tell you how to put it into valet mode.
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Tundra 2000 security [ « Previous ] [ Next » ]
