Home > Message Board > Car Audio > Security Systems > Archive through April 17, 2009 > Unlock code for alpine mf 2910
Author Thread: Unlock code for alpine mf 2910
Username: Tony_j
Graignamanagh, Kilkenny
Ireand
Hi does anybody have the unlock code for an alpine mf 2910 audio cd 10 the only number i can locate on the unit is 1708200386.
Thanks
Username: Tony_j
Ireland
serial No;al 2910x0945653
patr No;1708200386
Username: Regrooster
Post Number: 827
ALPINE codes are very difficult to calculate.
Try emailing restoredclassic@aol.com
who may be able to help.
Mention this forum and there should be no charge.
Username: Tony_j
Ireland
Thank you i have done that hopefully they can help.
Tony j
Username: Tony_j
Ireland
Hi everybody still no luck unlocking my radio. spoke to rep from alpine today he says its becker front of my radio just above cd insert says mercedes audio 10 casing when removed has mercedes emblem on white sticker beside that the numbers 170 820 0386 engraved into the black steel of radio the letters and numbers al2910 x 094 5653 ok its a 2910 but who makes it alpine / becker ? i have purchased codes waste of time and money im considerng pleading with to unlock itself. failing that im going to kick it around my back lawn.Have a nice day everybody.
Post Number: 866
If the codes provided by restoredclassic@aol.com did not work for you then either your radio is very secure and is a model that cannot be decoded using the Serial Number or it has been recoded in the past to a completely different number.
The only solution now is to take it into a Decoding Specialist or your local Car Radio / Audio Shop where they will electronically "read" / recode your radio`s memory chip (EEPROM) using a laptop and specialist Dump reading software.
Home > Message Board > Car Audio > Security Systems > Archive through April 17, 2009 > Unlock code for alpine mf 2910 [ « Previous ] [ Next » ]
