Home > Message Board > Car Audio > Security Systems > Archive through April 17, 2009 > Can you help me with code for Philips...
Author Thread: Can you help me with code for Philips car radio?
Username: Hoower
model 22DC229/62
RN22F10078722
FD0101350078722
Thank you !
Username: Decode
Post Number: 58
post numper like this
8200057676TX123
Username: Hoower
820057676TB165
Thank you
Username: Hoower
i forgot one 0
8200057676TB165
Username: Decode
Post Number: 59
hoower ------> code 0623
If this code has helped you in anyway - and you want to say thanks ,like beer donation:-)...
this is my paypal ( www.paypal.com ) e mail:
lynx222@o2.pl
Username: Hoower
not working this code 0623
Username: Hoower
not because I don`t want to drink your beer :-)
Username: Decode
Post Number: 60
8200057676TB165 this is correct number??
Username: Hoower
8200057676TB165
Username: Hoower
Post Number: 7
i have my radio on my desk. this is the number . another number is similar without TB165. I dont`t remember the code with 0 . I think is something with 1 and 9 , but I think the solution is to go to my service guy to tell him something about his mother. :-) ANd to bring some beers for you.
Username: Regrooster
Post Number: 791
model 22DC229/62
RN22F10078722
FD0101350078722
8200057676TB165
I suggest that you check your numbers again as RN22F10078722 should be 14 characters long (yours is only 13 ) and the code already given 0623 is the correct code using the Security Serial Number 8200057676TB165
Username: Hoower
Post Number: 8
ok , one moment
Username: Hoower
Post Number: 9
RN229F10078722 this is ok now
FD0101350078722
8200057676TB165
Post Number: 793
Yes..your code is definitely 0623
as originally stated
1...If your numbers are correct then 0623 is the original factory code.
2...Make sure you are entering it using the correct instruction and are getting the correct display at every stage.
(see below)
If all this checks out OK then it looks like your radio will have been recoded to a completely different number.
You will then have to take it to a Decoding Service .
Philips DC229 Renault Code Entry
Switch on the radio, the display will show 'CODE' followed by '0000'
Press the preset [1] for the correct first digit
Press the preset [2] for the correct second digit
Press the preset [3] for the correct third digit
Press the preset [4] for the correct fourth digit
If the correct code is now shown on screen, press and hold the [6] preset to save it.
Username: Hoower
Post Number: 10
You see the number RN229F10078722 is now with 14 characters. In your program it the same CODE with this new number ? Because 0623 don`t work . THANKS.
Post Number: 798
The code is still 0623
You will have to take it to a Decoding Service to read/recode your radio.
Cheerio !
Username: Hoower
Post Number: 11
don`t work but thanks
Home > Message Board > Car Audio > Security Systems > Archive through April 17, 2009 > Can you help me with code for Philips... [ « Previous ] [ Next » ]
