Home > Message Board > Car Audio > Multimedia Systems > Dual xdvd9101 brake bypass code Pleas...
Author Thread: Dual xdvd9101 brake bypass code Please help...
Username: Thefowlerfam2009
Holiday, FL
I just installed a new Dual xdvd9101. I grounded the parking brake and tried to bypass it with the 26604 code that I used on my xdvd700. I cant get it to work on this unit. Is there another code or way to bypass? Also I dont know if this has anything to do with it, but there isn't a enter button on the remote. Please help me with this one I am stumped. I have searched all over the internet and nothing. There really isn't alot of info on the xdvd9101.
Thanks for any and all help...
Jeremy
Holiday, FL
Can anyone help?? Im trying to avoid putting in a toggle switch.
Username: Randy628
Sioux City, Iowa
I got the XDVD9101 and after installing the unit it comes on for about 2 sec. and then turns off. I called tech support and thay told me i have a faulty unit so i exchanged it for another one. After installing the new one same problem. I drive a 99 Cadillac seville STS. I tryed to install it to just a batterie (full charged) i have in my shop same problem. Did some one have an answer for me please.
Thanks Randy
P.s: Yes I removed all the transporting screws.
Username: Randy628
Sioux City, Iowa
ok found the answer myself. U need to conect the yellow and red wire from the Radio togetter and the XDVD9101 works just fine.
Username: Garthur59
Tuscaloosa, AL.
Usa
I JUST GOT THE XDVD9101 INSTALLATION I NEED THE BYPASS CODE MYSELF. TRIED THE CODE 26604 DIDN'T WORK. CAN SOMEONE HELP ME OUT THERE?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Multimedia Systems > Dual xdvd9101 brake bypass code Pleas... [ « Previous ] [ Next » ]
