Home > Message Board > Car Audio > Security Systems > Archive through April 17, 2009 > Code for Renault Megane Radio: Tuner ...
Author Thread: Code for Renault Megane Radio: Tuner List
Username: Micheintz
Hi
I need the Code for my Renault Megane Radio.
It is a Model "Tuner List" from 2002
Model No: RENRDW132-10
V938 Security
Prod No: FD0404190076791
And i Find this Nummer on the right Site:
8200300859TV938
And under There:
8200300859 --B
Thank you for your Help
Mic
Username: Micheintz
I forgot the Company:
The radio is from Philips
Thank's
Michael
Username: Decode
Post Number: 47
Michael Heintz ------> code 4099
If this code has helped you in anyway - and you want to say thanks ,like beer donation:-)...
this is my paypal ( www.paypal.com ) e mail:
lynx222@o2.pl
Username: Micheintz
The Code don't works with my Radio !!!
Username: Decode
Post Number: 48
8200300859TV938---> it's correct number?? check it
Username: Micheintz
The Number is Correct !!
But I don't know, theres the Serial-Number ?!?!
Thanks
Michael
Username: Decode
Post Number: 49
for V938---> code is 4099 ..must have been recoded..or you are not entering it correctly..
Username: Micheintz
I don't know if the radio-Code is changed
I have bought the Radio at Ebay
S*H*I*T*..............
but thanks for your help !!!
MICHAEL
Username: Regrooster
Post Number: 768
A longshot...but try code 5092
Username: Decode
Post Number: 50
yes maybe it's U938 and then 5092 is good code
Username: Micheintz
Is not the correct Code !!
The Renault Support says :
He need the Number of the Car, to gernerate the Radio Code !
This is important for you ?
**** Michael
Username: Micheintz
Post Number: 7
Hi @all
I do not want more !!!!!
I send the radio back to the Ebayer
and want my money back !!!
Many thanks for your help
Michael
Home > Message Board > Car Audio > Security Systems > Archive through April 17, 2009 > Code for Renault Megane Radio: Tuner ... [ « Previous ] [ Next » ]
