Home > Message Board > Car Audio > Speakers > Archive through March 16, 2009 > 4 channel head unit driving 2 speaker...
Author Thread: 4 channel head unit driving 2 speakers and sound interference...On a PediCab
Username: Taekin
I do bar hopping tours in Victoria BC, and have a loud stereo and would like to make it just a little more powerful.
I am looking to see if it is possible for my 4 channel car deck to use on just two speakers? And if there is anything special I would need to do with the wires. Also if anyone knows
about sound interference. I have 30 feet of electro luminesent lighting that goes around the bike which is powered by the same battery as the stereo and an Ipod connected to 18feet of mini audio cable going to the car deck. When I turn on the electoluminesent lighting there is a high pitched hum that is played through the speakers, and also if the mini audio cable touches the metal frame while the lighting is on there is a very loud squeak. My question is would a more interference resistant audio cable actually help, since the interference is coming from all around the frame of the bike. Thank you
My current config is
panasonic CQ-C8301U car deck
17 W RMS x 4 Channels at 4 Ohms
ALPINE SPSM600 MARINE AUDIO/STEREO 6.5" 2-WAY SPEAKERS
Sensitivity 89dB
Frequency Response 60 - 22,000Hz
RMS Power Range 35 Watts
Peak Power Handling 110 Watts
Impedance 4Ohms
Home > Message Board > Car Audio > Speakers > Archive through March 16, 2009 > 4 channel head unit driving 2 speaker... [ « Previous ] [ Next » ]
