Thread: Viper Alarm 791xv |
New member Username: Schmitty915
Post Number: 1 Registered: Mar-09
| Posted on Friday, March 13, 2009 - 07:32 am: |
Hi - everything about my alarm system was working perfectly until yesterday i was in a fender bender...but didn't damage the car at all. However, now when i try to use the remote to lock the doors, it says it's out of range... i've been looking through many forum discussions & tried just reprogramming it (inition to on, push valet once then again & hold, press lock button) but that didn't work... does anyone know if there is a specific wire that may have been shaken loose or something that would cause this? Matt |
New member Username: Thawarrior10
Post Number: 6 Registered: Feb-09
| Posted on Monday, March 16, 2009 - 10:00 pm: |
check your alarm brain to make sure all the connectors are plugged in all the way |
Post Number: 2 Registered: Mar-09
| Posted on Tuesday, March 17, 2009 - 08:03 am: |
yea there was a wire loose in the antenna/signal receiver. thanks! |
