Home > Message Board > Car Audio > EQs and Crossovers > Equalizer/Booster wiring help
Author Thread: Equalizer/Booster wiring help
Username: Jokylos
Hello, I have a VERY old Pioneer BP-880 Graphic Eq/Booster that I want to re-install. The wires are as follows and are self explanatory..
Red-12v to ignition sw.
Red w/ white stripe - Connect to red constant
Black - Ground
Blue - Has 1 male and 1 female lead on the same wire to connect to system control terminal and auto-antenna respectively.
4 front left and right + and - wires
4 rear left and right + and - wires
1 set RCA jacks
The problem I have is there are also three additional wires
One solid black
One solid green
One gray w/ green stripe
I think those wires are booster input wires but where do they connect to the head unit? Head unit does not have any RCA jacks. Any info would be greatly appreciated. Thanks
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > EQs and Crossovers > Equalizer/Booster wiring help [ « Previous ] [ Next » ]
