Thread: Cd play |
New member Username: Pontiacman22
Waukeshua,
Wisconsin
Us
Post Number: 1 Registered: Mar-09
| Posted on Thursday, March 12, 2009 - 02:38 am: |
ok i have a stock cd player in my 07 pontiac g6 and i want to change it out with an after market cd player but i dont want to lose the gauges that tell me how many miles my gas has and trip meter and so on what could i do? |
New member Username: Joseito
Post Number: 3 Registered: Mar-09
| Posted on Tuesday, March 31, 2009 - 10:57 pm: |
as far as i know if you change the radio the computer's gona show the same as before, miles, trip and so on, just the radio station or cd (radio things)gona dissapear cause is a separate loom, try to remove your radio and see whats happens,make sure you got the code for it. good luck. |
New member Username: Kelly123
Post Number: 7 Registered: Jul-08
| Posted on Wednesday, April 01, 2009 - 03:25 am: |
If you don't want to lose the gauges, you can buy a cd changer install in your car. you can go to this http://www.car-cd-changer.net |
Post Number: 8 Registered: Jul-08
| Posted on Friday, September 04, 2009 - 01:35 am: |
This idea is very good. http://www.car-cd-changer.net |
